[Bug] Gladys restart always
Je reviens vers vous suite à un problème sur mon Gladys.
0|gladys  | Error: connect ETIMEDOUT 5.54.23.134:55443
0|gladys  |     at Object._errnoException (util.js:1022:11)
0|gladys  |     at _exceptionWithHostPort (util.js:1044:20)
0|gladys  |     at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1182:14)
0|gladys  | Warning: connect.session() MemoryStore is not
0|gladys  | designed for a production environment, as it will leak
0|gladys  | memory, and will not scale past a single process.
0|gladys  | =*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=*=
0|gladys  | WARNING: You currently have your default CORS settings configured to allow
0|gladys  | all requests from all origins, with credentials.  This may leave your app
0|gladys  | open to attack by third-party sites!  Consider making your `origins` setting
0|gladys  | more restrictive or setting `credentials` to false, or else make certain that
0|gladys  | none of your routes perform sensitive actions or reveal secure information.
Mon gladys redémarre toute les 10 secondes … C’est chiant mdr
Des idées de pourquoi ca ferait ca ? Merci.
