Hi there. Brand new user, found Gladys from the post on Reddit yesterday. I am the target market
I cannot log in. I’ve flashed the Gladys image from the official Raspberry Pi site and I cannot log in using the usual default username/password combination pi/raspberry.
A shame, I have fallen at the first hurdle.
Any help/suggestions?
Hi guy, for raspberry it’s “pi” “raspberry” for gladys you have just to connect on your rapsberry’s ip on port 80, at the first connection nromally you’ll put the username and password you 'll want
Ok, so while I partially understand your answer I was attracted to the Glasys assistant becuase when Pierre-Gilles was on Reddit yesterday he was selling it as the “home assistant for non-tech types”.
So maybe this assisnt isn’t for me after all - If I’m having trouble even just logging in!
Perhaps I’ll just wait until the project takes off more and there are more English language YouTube videos.
Hello. You don’t need to use SSH to connect to your Raspberry Pi.
Once you boot your Gladys instance, it’s available through IP or domain gladys.local.
The first time you are accessing your instance, you will have few pages to Setup your instance and to create your user account. There is no default user/password.
A: Plug in the pi with Gladys flashed onto it. That’s it, just leave it alone
B: Go to another computer on the same network and put the address http:/raspberrypi.local into a browser. Putting in either gladys.local or the IP address of the pi did not work for me. Perhaps because I got the Raspberry Pi official version from the Pi website?
Thank you all. My mistake was to assume that I needed to log into the Gladys Pi machine locally.
I see now that access is from my browser on another machine.
