# Connection to Zigbee2mqtt to see network visualisation not working
**URL:** <https://community.gladysassistant.com/t/connection-to-zigbee2mqtt-to-see-network-visualisation-not-working/9940>\
**Tags:** zigbee2mqtt\
**Created:** [January 31, 2026, 3:53pm UTC](https://community.gladysassistant.com/t/connection-to-zigbee2mqtt-to-see-network-visualisation-not-working/9940 "2026-01-31T15:53:12Z")\
**Showing post:** 4
**Post date:** [January 31, 2026, 5:33pm UTC](https://community.gladysassistant.com/t/connection-to-zigbee2mqtt-to-see-network-visualisation-not-working/9940/4 "2026-01-31T17:33:37Z")
Good news for the config!
Have you tried changing `node-16` to your Gladys’s IP address?
And then you directly put `http://192.168.X.Y:12001` (well, the correct IP of your Gladys).
EDIT: @NoiZe also had access issues with the port and was able to resolve it: [Use another port for Zigbee2MQTT dashboard? - #6 par NoiZe](https://community.gladysassistant.com/t/use-another-port-for-zigbee2mqtt-dashboard/9860/6?u=mutmut)
_[View the full topic](https://community.gladysassistant.com/t/connection-to-zigbee2mqtt-to-see-network-visualisation-not-working/9940)._
