# Hyundai unable to connect
**URL:** <https://community.gladysassistant.com/t/hyundai-impossible-de-se-connecter/11359>\
**Category:** Développement\
**Created:** [October 19, 2026, 9:50am UTC](https://community.gladysassistant.com/t/hyundai-impossible-de-se-connecter/11359 "2026-10-19T09:50:55Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![Prof\_Techno](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/prof_techno/32/19038_2.png) [@Prof\_Techno](https://community.gladysassistant.com/u/Prof_Techno)\
**Post date:** [October 19, 2026, 9:50am UTC](https://community.gladysassistant.com/t/hyundai-impossible-de-se-connecter/11359/1 "2026-10-19T09:50:56Z")
</div>
Hello
I’m currently testing the Hyundai integration, but I can’t connect it at the moment: I’m hitting a brick wall.
 ![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/9/1/91dfa5a3d07b366e619b6d3a30def263c13ba425.png)
I don’t know if the problem is due to the fact that the Hyundai app is now called MyHyundai, even though Bluelink still works in the background. Could this explain the connection problem with the Gladys integration?
 ![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/4/c/4c27f8eb1d615c82b581ef49f474c54409115f2a.png)
I’m pinging the integration creator @guim31
**Author:** ![guim31](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/guim31/32/4840_2.png) [@guim31](https://community.gladysassistant.com/u/guim31)\
**Post date:** [October 19, 2026, 10:01am UTC](https://community.gladysassistant.com/t/hyundai-impossible-de-se-connecter/11359/2 "2026-10-19T10:01:41Z")
</div>
Hi @Prof_Techno, thanks for the feedback and the screenshot, it helped!
It’s not the app’s name: since October 14th, Hyundai and Kia require a signature on connection requests in Europe, and the integration wasn’t sending it. This is fixed in **1.1.2** (same fix as the library used by Home Assistant). Update from Gladys, then restart « Test the connection ».
I don’t have a Hyundai account to test it for real: let me know if it works 🙂
**Post date:** [October 19, 2026, 10:12am UTC](https://community.gladysassistant.com/t/hyundai-impossible-de-se-connecter/11359/3 "2026-10-19T10:12:40Z")
</div>
> [@guim31](#):
> My Hyundai account to test in real life:
Everything works, it’s perfect!!
I tested starting and stopping the charge from the dashboard, and everything works correctly. Now I just need to test these actions in scenes to see if everything works just as well on that side.
