# 🔥 Aduro integration: control your hybrid pellet stove from Gladys
**URL:** <https://community.gladysassistant.com/t/integration-aduro-pilotez-votre-poele-a-granules-hybride-depuis-gladys/11676>\
**Category:** Développement\
**Created:** [November 25, 2026, 10:10pm UTC](https://community.gladysassistant.com/t/integration-aduro-pilotez-votre-poele-a-granules-hybride-depuis-gladys/11676 "2026-11-25T22:10:08Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![McFlyPartages](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/mcflypartages/32/15670_2.png) [@McFlyPartages](https://community.gladysassistant.com/u/McFlyPartages)\
**Post date:** [November 25, 2026, 10:10pm UTC](https://community.gladysassistant.com/t/integration-aduro-pilotez-votre-poele-a-granules-hybride-depuis-gladys/11676/1 "2026-11-25T22:10:08Z")
</div>
[![](https://raw.githubusercontent.com/McFlyPartages/gladys-aduro/main/docs/images/cover.png) ](https://raw.githubusercontent.com/McFlyPartages/gladys-aduro/main/docs/images/cover.png)
# 🔥 Aduro Integration: Control Your Hybrid Pellet Stove from Gladys
I present to you a new external integration for Gladys: **Aduro** , which allows you to control and monitor **Aduro hybrid pellet stoves** (H1, H2, H3, and H5 confirmed; H4 and H6 probable).
It communicates **directly with the stove on your local network** , using the same protocol as the Aduro Hybrid app. No account, no cloud: Aduro’s cloud relay exists as a backup, but it is disabled by default.
This is a port for Gladys of the Home Assistant integration [NewImproved/Aduro](https://github.com/NewImproved/Aduro) and the library [pyduro](https://github.com/clementprevot/pyduro). Thanks to their authors!
> ⚠ **Unofficial** integration, with no link to Aduro. This is a **test version** : your feedback is welcome.
## What You Can Do
**Control the Stove**
- Start / stop
- Power **I, II, or III**
- Set temperature (5 to 35 °C)
- Operating mode: power, temperature, or wood
- Each change is followed until the stove applies it, and sent back if it doesn’t.
**Monitor the Stove**
- Ambient, flue, and chimney temperatures
- Heating power, carbon monoxide
- Status and clear details, with countdown during ignition
- Pellet consumption: day, previous day, month, year, total
- Hopper level, in % and kg
- Stove, auger, and ignition operating time
**Automations**
- Automatic shutdown when pellets are too low
- Automatic return to pellets when the wood fire goes out
- Forced fan and auger, with maximum duration
- “Pellets refilled”, “Stove cleaned”, “Reset alarm” buttons
**Pellet End Prediction** (power mode): the integration learns on its own what your stove consumes at each power level, then announces the time when the hopper will be empty. Example: “Wed, Nov 25, 11:30 PM (reliable)”.
## Dashboard Widgets
 ![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/1/3/135bc11fadd7c4406f11bd5367c0d13284b9134d.jpeg)
### 1. The Animated Stove
A drawing of the stove that follows its real-time status:
| Ignition | Small Flame | Medium Flame | Large Flame | Wood Mode |
- **Ignition** : the crucible glows, the smoke rises, the indicator flashes. No flame yet.
- **Heating** : small, medium, or large flame, depending on the chosen power.
- **Wood Mode** : the logs burn, with sparks.
- **Off or Waiting** : the window is off.
Below the drawing, you find the temperature of the **firebox** and the **ambient** temperature in real-time, the stove status, and four buttons:
- **Start the stove** or **Turn off the stove** (shutdown requires confirmation)
- **Small Flame** , **Medium Flame** , **Large Flame**
### 2. Statistics
- Check pellet level, remaining autonomy
- Daily, monthly and yearly consumption, heating power
- Graph of pellets burned **per day** (last 31 days) or **per month** (last 12 months), choose in the widget settings
- Expected end of pellets
- Flue and chimney temperatures
- Carbon monoxide, in orange or red above the stove thresholds
- Operating time
- Learned consumption at each power (kg/h)
## Scenes
Five scene triggers are available:
- 🔥 **Stove flue too hot** (adjustable threshold and duration)
- 🪵 **Stove wood fire weakening**
- 📉 **Stove pellets low** , with remaining kg
- ⛔ **Stove stopped due to lack of pellets**
- ⚠ **Stove fault** , with the code and label of the state
For example: « Stove pellets low » → message « There are {{triggerEvent.data.remaining\_kg}} kg of pellets left, remember to refill! »
## Installation
1. Install the **Aduro** integration from the Gladys integrations catalog (Gladys 5.1.0 minimum).
2. Enter the **serial number** and **PIN code** of the stove (on its label, these are the ones from the Aduro app), then its **IP address**.
3. Add the stove in the Devices tab, then the widgets in your dashboard.
💡 If the stove is on a different network (VLAN) than Gladys, specify its IP address: automatic search does not cross VLANs. The stove listens on **UDP port 8483**.
The complete documentation is available: network and firewall, settings, scenes, troubleshooting.
## Feedback welcome
This is a first version, tested so far on a single stove. If you have an Aduro, your feedback is particularly interesting to me on:
- your **model** (especially if you have an H4 or an H6);
- the states displayed « **Unknown state (NN)** »: note the code;
- the power and temperatures, compared to those of the Aduro app.
- Source code and issue tracking: [GitHub - McFlyPartages/gladys-aduro · GitHub](https://github.com/McFlyPartages/gladys-aduro)
- Documentation: [gladys-aduro/docs/fr.md at main · McFlyPartages/gladys-aduro · GitHub](https://github.com/McFlyPartages/gladys-aduro/blob/main/docs/fr.md)
Happy heating! 🔥
**Post date:** [November 26, 2026, 8:59pm UTC](https://community.gladysassistant.com/t/integration-aduro-pilotez-votre-poele-a-granules-hybride-depuis-gladys/11676/2 "2026-11-26T20:59:35Z")
</div>
Sorry, I realized I hadn’t published the integration in the catalog.
I just added the topic.
Now we have to wait.
Sorry.
