@bertrandda j’ai retrouvé une branche avec la télécommande sur le dashboard, elle est très vielle, je viens de la mettre à jour avec le la dernière version du code, mais je pense qu’elle ne fonctionne pas en l’état.
Je n’aurais pas le temps de me remettre à travailler sur le sujet, mais si ça peut t’inspirer.
atrovato:master ← atrovato:remote-box
opened 06:40PM - 03 Jul 23 UTC
### Pull Request check-list
- [ ] If your changes affects code, did your write the tests?
- [ ] Are tests passing? (`npm test` on both front/server)
- [ ] Is the linter passing? (`npm run eslint` on both front/server)
- [ ] Did you run prettier? (`npm run prettier` on both front/server)
- [ ] If you are adding a new features/services, did you run integration comparator? (`npm run compare-translations` on front)
- [ ] Did you test this pull request in real life? With real devices? If this development is a big feature or a new service, we recommend that you provide a Docker image to [the community](https://community.gladysassistant.com/) for testing before merging.
### Description of change
Please provide a description of the change here. It's always best with screenshots, so don't hesitate to add some!
(tout n’est pas à garder)
