# Integration of Canadian energy supplier Hydro-Québec
**URL:** <https://community.gladysassistant.com/t/integration-du-fournisseur-denergie-canadien-hydro-quebec/10688>\
**Category:** Configuration\
**Created:** [August 21, 2026, 1:09pm UTC](https://community.gladysassistant.com/t/integration-du-fournisseur-denergie-canadien-hydro-quebec/10688 "2026-08-21T13:09:47Z")\
**Posts on this page:** 5\
**Page:** 1
<div class="post-metadata">
**Author:** ![lmilcent](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/lmilcent/32/7023_2.png) [@lmilcent](https://community.gladysassistant.com/u/lmilcent)\
**Post date:** [August 21, 2026, 1:09pm UTC](https://community.gladysassistant.com/t/integration-du-fournisseur-denergie-canadien-hydro-quebec/10688/1 "2026-08-21T13:09:47Z")
</div>
🔌 Hydro-Québec Integration for Gladys
I just published an external integration to monitor your Hydro-Québec account directly in Gladys: daily consumption, average temperature, account balance, outages, and for dynamic pricing, the peaks of the Winter Credit (CPC) and Flex D (DPC).
It relies on hydroqc ([hydroqc / Hydro Quebec API Wrapper · GitLab](https://gitlab.com/hydroqc/hydroqc)), the same library as the equivalent Home Assistant integration: no reinvented Hydro-Québec logic, just a bridge to a mature tool maintained by the community.
Repository: [GitHub - LM1LC3N7/Gladys-Hydro-Quebec: Hydro-Québec integration to Gladys Assistant, based on hydroqc library used by Home Assistant. · GitHub](https://github.com/LM1LC3N7/Gladys-Hydro-Quebec)
Tested in real conditions on a D-rate account, with a secondary meter. However, I have no feedback yet for an account registered for Winter Credit or Flex D. If that’s your case, your feedback (and bug reports) are welcome directly on the GitHub repository!
**Post date:** [August 21, 2026, 1:10pm UTC](https://community.gladysassistant.com/t/integration-du-fournisseur-denergie-canadien-hydro-quebec/10688/2 "2026-08-21T13:10:52Z")
</div>
@administrators do I leave this here or should we move it elsewhere? In essence, it’s a feature request, but one that’s already tested and functional 😊
**Author:** ![Will\_71](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/will_71/32/9582_2.png) [@Will\_71](https://community.gladysassistant.com/u/Will_71)\
**Post date:** [August 21, 2026, 1:16pm UTC](https://community.gladysassistant.com/t/integration-du-fournisseur-denergie-canadien-hydro-quebec/10688/3 "2026-08-21T13:16:01Z")
</div>
In External Integration Development for example.
![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/2/c/2c4e8b53686e0dc67b8ed7e4d4e56ddc732e5215.png)
**Post date:** [August 21, 2026, 1:47pm UTC](https://community.gladysassistant.com/t/integration-du-fournisseur-denergie-canadien-hydro-quebec/10688/4 "2026-08-21T13:47:27Z")
</div>
Moving the message doesn’t work because of the «&nbsp;to-be-processed&nbsp;» tag in the topic 😕
**Post date:** [August 21, 2026, 4:23pm UTC](https://community.gladysassistant.com/t/integration-du-fournisseur-denergie-canadien-hydro-quebec/10688/5 "2026-08-21T16:23:18Z")
</div>
yes it’s a problem even for admins ☹
I’m marking the topic as Resolved, I don’t have any other solutions for now to set it aside (or even just Close it)
