# Freebox external integration
**URL:** <https://community.gladysassistant.com/t/integration-externe-freebox/11384>\
**Category:** Développement\
**Created:** [October 20, 2026, 8:57pm UTC](https://community.gladysassistant.com/t/integration-externe-freebox/11384 "2026-10-20T20:57:01Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![StephaneB](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/stephaneb/32/15443_2.png) [@StephaneB](https://community.gladysassistant.com/u/StephaneB)\
**Post date:** [October 20, 2026, 8:57pm UTC](https://community.gladysassistant.com/t/integration-externe-freebox/11384/1 "2026-10-20T20:57:01Z")
</div>
@Will_71 I installed your integration without any issues and my pop server is properly detected. Just two suggestions:
- In the documentation (or the ‹&nbsp;configuration&nbsp;› screen, I don’t remember…) you explain that certain rights need to be added in FreeboxOS. But I wondered if I should leave all the ones that are checked by default, or if I could remove them
- The ‹&nbsp;network devices&nbsp;› widget displays a few, then indicates «&nbsp;and N more&nbsp;». Would it be possible to click on this message and have a window open to display everything? Or to have next/previous buttons to paginate this list?
- The ‹&nbsp;freebox&nbsp;› widget is really cool. Would it be possible to navigate through time, like with a ‹&nbsp;graph&nbsp;› widget? But as I write this, I realize that I just need to display a graph widget with the devices that your integration has created…
**Author:** ![Will\_71](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/will_71/32/9582_2.png) [@Will\_71](https://community.gladysassistant.com/u/Will_71)\
**Post date:** [October 20, 2026, 9:18pm UTC](https://community.gladysassistant.com/t/integration-externe-freebox/11384/2 "2026-10-20T21:18:39Z")
</div>
![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/d/9/d9b5e1664e1fc79bfb1df1f7b587b24f3b78fde6.png)
Here is the list, but no, you don’t have to leave everything, you just need to take what you need.
For the network widget, we are limited in the number of lines displayed, so I can’t add more. I’ll check if it’s possible to navigate through the list with buttons.
Navigating through time in the widget’s graph, I don’t know if it’s possible. If we can, I’ll add it. But in the meantime, yes, with the device created, you can redraw a curve.
