# IPX800 integration
**URL:** <https://community.gladysassistant.com/t/integration-ipx800/11448>\
**Category:** Développement\
**Created:** [October 29, 2026, 7:53pm UTC](https://community.gladysassistant.com/t/integration-ipx800/11448 "2026-10-29T19:53:23Z")\
**Posts on this page:** 1\
**Page:** 2
<div class="post-metadata">
**Author:** ![lmilcent](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/lmilcent/32/7023_2.png) [@lmilcent](https://community.gladysassistant.com/u/lmilcent)\
**Post date:** [November 19, 2026, 1:41am UTC](https://community.gladysassistant.com/t/integration-ipx800/11448/22 "2026-11-19T01:41:58Z")
</div>
Thanks @cce66! First, a small correction: you have a Sagem SC10, not a Linky, so my comment about the „standard mode“ didn’t apply. Your BASE is indeed filled in Get=TI (132,852,908 Wh), it’s the same index that the integration already reads.
It’s in **v0.2.0** of the RT2 integration: [Release v0.2.0 · LM1LC3N7/gladys-ecodevices-rt2 · GitHub](https://github.com/LM1LC3N7/gladys-ecodevices-rt2/releases/tag/v0.2.0) (it will arrive in the store at the next indexer update).
To activate it, add `TIC` and the posts you use (for example `P1`) in the **Extensions** field, then create the new devices in the Discovery tab. With your responses, Gladys will display:
- **Téléinformation 1** : apparent power (870 VA in your case), current (4 A), and tariff period („All hours“ for TH..);
- **Post n** : instantaneous power of each listed post. Only the posts you list are created, because a post without a clamp also reads 0 and we can’t distinguish them.
What already existed doesn’t change. TIC and posts are only read if you add them, and if they don’t respond, the rest (relays, inputs, index) is still published, with „not read“ in the status.
Two questions when you have a load on a post: does the power of the posts display correctly in **W**? GCE doesn’t specify. And is your meter single-phase? Three-phase (IINST1 to 3) is not yet read.
[Previous page](https://community.gladysassistant.com/t/integration-ipx800/11448.md?page=1)
