# \[Integration\] : The TEC — buses, trams and metro of Wallonia
**URL:** <https://community.gladysassistant.com/t/integration-le-tec-bus-trams-et-metro-de-wallonie/11162>\
**Category:** Développement\
**Created:** [October 14, 2026, 1:25pm UTC](https://community.gladysassistant.com/t/integration-le-tec-bus-trams-et-metro-de-wallonie/11162 "2026-10-14T13:25:04Z")\
**Posts on this page:** 1\
**Page:** 1
<div class="post-metadata">
**Author:** ![GBoulvin](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/gboulvin/32/10006_2.png) [@GBoulvin](https://community.gladysassistant.com/u/GBoulvin)\
**Post date:** [October 14, 2026, 1:25pm UTC](https://community.gladysassistant.com/t/integration-le-tec-bus-trams-et-metro-de-wallonie/11162/1 "2026-10-14T13:25:04Z")
</div>
Hello everyone!
I present to you an external integration to follow the **TEC** network directly in Gladys: buses, Liège trams, and Charleroi metro, **with real-time delays and disruptions**.
**What it does**
- A device per monitored stop (with optional line filter): next departure in minutes, «&nbsp;M2 → Anderlues · 08:03 (+3 min)&nbsp;», delay, next departure, list of upcoming departures, number of disruptions.
- **Scene triggers** : «&nbsp;TEC departure imminent&nbsp;» (1 to 30 minutes before), «&nbsp;Delayed departure&nbsp;», «&nbsp;Cancelled departure&nbsp;», «&nbsp;New disruption&nbsp;».
- **Scene actions** : get the next departure (ideal for a message «&nbsp;Your bus is leaving in 5 minutes!&nbsp;») or check if a line is disrupted.
- **Widgets** : departure board for a stop, and the list of disruptions on your lines.
- Stop search by name or around your home, directly from the configuration screen.
- Available in French, English, German, and Spanish.
**Data** : TEC open data schedules + real-time data from the Belgian Mobility portal. It works without an account. A free API key allows a refresh every minute instead of 20.
**Installation** : Gladys ≥ 5.1, from the integrations store («&nbsp;TEC&nbsp;»).
Code and documentation: [GitHub - gboulvin/LeTEC · GitHub](https://github.com/gboulvin/LeTEC)
Your feedback is welcome, especially if you take the metro or tram daily! 🚇
