# Liste de possibles améliorations UX/UI (StéphaneB)
**URL:** <https://community.gladysassistant.com/t/liste-de-possibles-ameliorations-ux-ui-stephaneb/9308>\
**Created:** [Janvier 20, 2025, 10:19 UTC](https://community.gladysassistant.com/t/liste-de-possibles-ameliorations-ux-ui-stephaneb/9308 "2025-01-20T10:19:57Z")\
**Showing post:** 12
**Post date:** [Janvier 27, 2025, 5:17 UTC](https://community.gladysassistant.com/t/liste-de-possibles-ameliorations-ux-ui-stephaneb/9308/12 "2025-01-27T17:17:58Z")
Bug de la recherche dans les scènes qui saute corrigé :
> <https://github.com/GladysAssistant/Gladys/pull/2215>
> \### Pull Request check-list
> To ensure your Pull Request can be accepted as fa…st as possible, make sure to review and check all of these items:
> \- \[x\] If your changes affects code, did your write the tests?
> \- \[x\] Are tests passing? (\`npm test\` on both front/server)
> \- \[x\] Is the linter passing? (\`npm run eslint\` on both front/server)
> \- \[x\] Did you run prettier? (\`npm run prettier\` on both front/server)
> \- \[x\] If you are adding a new features/services, did you run integration comparator? (\`npm run compare-translations\` on front)
> \- \[x\] Did you test this pull request in real life? With real devices? If this development is a big feature or a new service, we recommend that you provide a Docker image to the community (\[french forum\](https://community.gladysassistant.com/)/\[english forum\](https://en-community.gladysassistant.com/)) for testing before merging.
> \### Description of change
> Fix https://github.com/GladysAssistant/Gladys/issues/2214
Peut-être testé facilement ici : [https://fix-scene-search-lag.gladys-plus.pages.dev](https://fix-scene-search-lag.gladys-plus.pages.dev/)
_[View the full topic](https://community.gladysassistant.com/t/liste-de-possibles-ameliorations-ux-ui-stephaneb/9308)._
