# Problème de lien lors de la suppression d'un appareil MQTT
**URL:** <https://community.gladysassistant.com/t/probleme-de-lien-lors-de-la-suppression-dun-appareil-mqtt/10453>\
**Category:** Développement\
**Tags:** bug\
**Created:** [Août 4, 2026, 10:13 UTC](https://community.gladysassistant.com/t/probleme-de-lien-lors-de-la-suppression-dun-appareil-mqtt/10453 "2026-08-04T22:13:08Z")\
**Posts on this page:** 2\
**Page:** 1
<div class="post-metadata">
**Author:** ![prohand](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/prohand/32/15713_2.png) [@prohand](https://community.gladysassistant.com/u/prohand)\
**Post date:** [Août 4, 2026, 10:13 UTC](https://community.gladysassistant.com/t/probleme-de-lien-lors-de-la-suppression-dun-appareil-mqtt/10453/1 "2026-08-04T22:13:08Z")
</div>
Lors de la suppression d’un appareil MQTT j’ai eu le message suivant qui semble avoir un lien qui ne fonctionne pas :
 ![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/3/f/3f16c084b1a9a5a017b50ea6aadcab1d6739db04.png)
@pierre-gilles Tu pourrais y regarder quand tu pourra stp ? 🙂
**Author:** ![pierre-gilles](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/pierre-gilles/32/5886_2.png) [@pierre-gilles](https://community.gladysassistant.com/u/pierre-gilles)\
**Post date:** [Août 5, 2026, 5:58 UTC](https://community.gladysassistant.com/t/probleme-de-lien-lors-de-la-suppression-dun-appareil-mqtt/10453/2 "2026-08-05T05:58:41Z")
</div>
Merci pour le retour, j’ai lancé Claude dessus depuis la salle de sport 😁
> <https://github.com/GladysAssistant/Gladys/pull/2777>
> The MQTT device list and the Matter device box displayed the
> device.tooMuchState…sToDelete translation with \<Text\>, which escapes HTML.
> The link to the background jobs page was therefore printed as raw markup
> instead of being rendered as a clickable link.
> Use \<MarkupText\> like every other integration does, and drop a stray
> leading space inside the French link label.
> Co-Authored-By: Claude Opus 5 \<noreply@anthropic.com\>
> Claude-Session: https://claude.ai/code/session\_01GDJ9X5B24E2EWmMztLQRWP
