Probleme installation sur ubuntu 18.10
Bonjour a toute et tous,
voila voila,
je suis nouveau sur Gladys…
j’ai essayer de l’installer sur Ubuntu 18.10…
mais mon problème et récurant …
je vous joint le log ici—> d’avance un grand merci pour vos reponce !
bonne soirée a la communauté :slight_smile:
ps: je suis sur une machine virtuel(virtualbox).
logs: > [email protected] install /home/darian/gladys/node_modules/bcrypt
node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Pre-built binaries not installable for [email protected] and [email protected] (node-v57 ABI, glibc) (falling back to source compile with node-gyp)
node-pre-gyp WARN Hit error EACCES: permission denied, mkdir ‘/home/darian/gladys/node_modules/bcrypt/lib’
gyp ERR! configure error
gyp ERR! stack Error: EACCES: permission denied, mkdir ‘/home/darian/gladys/node_modules/bcrypt/build’
gyp ERR! System Linux 4.18.0-21-generic
gyp ERR! command “/usr/bin/node” “/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js” “configure” “–fallback-to-build” “–module=/home/darian/gladys/node_modules/bcrypt/lib/binding/bcrypt_lib.node” “–module_name=bcrypt_lib” “–module_path=/home/darian/gladys/node_modules/bcrypt/lib/binding” “–napi_version=4” “–node_abi_napi=napi”
gyp ERR! cwd /home/darian/gladys/node_modules/bcrypt
gyp ERR! node -v v8.16.0
gyp ERR! node-gyp -v v3.8.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute ‘/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/darian/gladys/node_modules/bcrypt/lib/binding/bcrypt_lib.node --module_name=bcrypt_lib --module_path=/home/darian/gladys/node_modules/bcrypt/lib/binding --napi_version=4 --node_abi_napi=napi’ (1)
node-pre-gyp ERR! stack at ChildProcess. (/home/darian/gladys/node_modules/bcrypt/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
node-pre-gyp ERR! stack at emitTwo (events.js:126:13)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:214:7)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:915:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:209:5)
node-pre-gyp ERR! System Linux 4.18.0-21-generic
node-pre-gyp ERR! command “/usr/bin/node” “/home/darian/gladys/node_modules/bcrypt/node_modules/.bin/node-pre-gyp” “install” “–fallback-to-build”
node-pre-gyp ERR! cwd /home/darian/gladys/node_modules/bcrypt
node-pre-gyp ERR! node -v v8.16.0
node-pre-gyp ERR! node-pre-gyp -v v0.10.2
node-pre-gyp ERR! not ok
npm WARN optional SKIPPING OPTIONAL DEPENDENCY: [email protected] (node_modules/fsevents):
npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for [email protected]: wanted {“os”:“darwin”,“arch”:“any”} (current: {“os”:“linux”,“arch”:“x64”})
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] install: node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! /home/darian/.npm/_logs/2019-06-13T17_24_04_777Z-debug.log
Bonjour et bienvenu,
Gladys v3 tourne sous NodeJs v8, pas sur les versions ultérieures.
Avec la commande nodejs -v tu sauras quelle est ta version.
En cherchant sur Google, tu trouveras le moyen de downgrader ta version.
Salut Alex,
Un grand merci à vous…
Je vient de regarder, je suis en 8.16.0
Je vais regarder à ça demain pour refaire une installation au propre :slight_smile:
J’ai vu pour le Downgrade , je l’ai fait sur Windows et ok :slight_smile: demain je le fais sous Linux (ubuntu 18.10)…
Une fois que tout est ok, je m’amuser à faire des petite vidéo sur ( Rpi-Windows-linux) :slight_smile:
Voilà voilà !
Je reviens demain ici pour confirmer :slight_smile:
Bonne soirée et nuit.
Bien à vous
Bonsoir :slight_smile:
Voilà problème réglé :wink: tout est fonctionnel…
Je commence les vidéo tutoriel demain sur toute les plateformes :slight_smile: ainsi que sur orange pi et odroid…
Encore un très très grand merci :slight_smile:
Bonne soirée ++
Ah bon? :smile:
Sur TravisCI, Gladys 3 est testée sur Node 8 et 10, il me semble que ça tourne sur les deux! (Node 12 pas testé par contre)
Je confirme ça tourne sur la lts donc la 10
Ok, au temps pour moi, il me semblait avoir eu des problème justement avec node-pre-gyp en NodeJS 10. Mais je dois confondre.
bonjour a tous,
voila ici je fait ma petite installation sur Windows,
voila ce que j’obtiens comme erreur …
encore un grand merci pour vos reponce :slight_smile:
Warning: connect.session() MemoryStore is not
designed for a production environment, as it will leak
memory, and will not scale past a single process.
WARNING: You currently have your default CORS settings configured to allow
all requests from all origins, with credentials. This may leave your app
open to attack by third-party sites! Consider making your origins setting
more restrictive or setting credentials to false, or else make certain that
none of your routes perform sensitive actions or reveal secure information.
Bootstrap encountered an error: (see below)
Error: Cannot find module ‘…/build/Release/nodessl.node’
at Function.Module._resolveFilename (module.js:485:15)
at Function.Module._load (module.js:437:25)
at Module.require (module.js:513:17)
at require (internal/module.js:11:18)
at Object. (C:\Users\pirat\Documents\Gladys\node_modules\node-webcrypto-ossl\buildjs\native.js:3:16)
at Module._compile (module.js:569:30)
at Object.Module._extensions…js (module.js:580:10)
at Module.load (module.js:503:32)
at tryModuleLoad (module.js:466:12)
at Function.Module._load (module.js:458:3)
at Object. (C:\Users\pirat\Documents\Gladys\node_modules\node-webcrypto-ossl\buildjs\key_storage.js:8:16)
at Object. (C:\Users\pirat\Documents\Gladys\node_modules\node-webcrypto-ossl\buildjs\webcrypto.js:5:23)
Oui avec certains modules je crois
