# Clock synchronization issue
**URL:** <https://community.gladysassistant.com/t/probleme-synchronisation-horloge/11641>\
**Category:** Configuration\
**Created:** [November 22, 2026, 9:17am UTC](https://community.gladysassistant.com/t/probleme-synchronisation-horloge/11641 "2026-11-22T09:17:43Z")\
**Posts on this page:** 4\
**Page:** 1
<div class="post-metadata">
**Post date:** [November 22, 2026, 9:17am UTC](https://community.gladysassistant.com/t/probleme-synchronisation-horloge/11641/1 "2026-11-22T09:17:43Z")
</div>
Gladys told me that I’m late on the clock.
 ![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/f/e/fe87dd718bc01c78bab5eaa3324f1b090ea27a9d.png)
So I click on Activate Sync and then on Verify again and the same message appears.
I deduce that nothing (or something bad) is happening.
And no info in the logs.
EDIT: 3-node Proxmox/LXC cluster environment
**Author:** ![Will\_71](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/will_71/32/9582_2.png) [@Will\_71](https://community.gladysassistant.com/u/Will_71)\
**Post date:** [November 22, 2026, 10:31am UTC](https://community.gladysassistant.com/t/probleme-synchronisation-horloge/11641/2 "2026-11-22T10:31:37Z")
</div>
On my side, the clock is up to date, but I can’t enable automatic synchronization.
Same LXC configuration on Proxmox
**Post date:** [November 22, 2026, 11:16am UTC](https://community.gladysassistant.com/t/probleme-synchronisation-horloge/11641/3 "2026-11-22T11:16:01Z")
</div>
Claude is on it and indeed it’s not possible to synchronize the clock with an LXC.
On my end, it was my 3-node cluster that was no longer on time 😬 and that one I didn’t see coming. In my defense… well no actually, I had forgotten to do a few steps after my IP network migration and the nodes no longer had access to the Internet and therefore to NTP… apparently since the beginning of September 🤨 what a klutz I can be sometimes ☹
**Post date:** [November 22, 2026, 11:22am UTC](https://community.gladysassistant.com/t/probleme-synchronisation-horloge/11641/4 "2026-11-22T11:22:42Z")
</div>
It’s coming back in order, but there are still messages to start the sync, I’m on a PR.
 ![image](https://gladys-assistant-community.b-cdn.net/uploads/default/original/3X/d/b/db8c14297515d7a3a4f4f3155eb0ee9fe4c85777.png)
