[RÉSOLU] Impossible de créer un devices
je vous suit depuis très longtemps mais je m’étais jamais lancé. Mais aujourd’hui c’est fait.
Je veux pour mes début avec Gladys commander des prises.
J’ai donc commencé à tout installer branché un arduino, un module émetteur et un récepteur installer les modules adéquats.
Mais impossible de créer un device
Etant un très très grand débutant je ne comprend pas grand chose au rapport de log. Avez vous une idée de ce qui arrive à Gladys
pi@gladys:~ $ pm2 logs
[TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
/home/pi/.pm2/pm2.log last 15 lines:
PM2 | [2019-01-27 14:30:08] PM2 log: App [gladys] with id [0] and pid [648], exited with code [0] via signal [SIGINT]
PM2 | [2019-01-27 14:30:08] PM2 log: Starting execution sequence in -fork mode- for app name:gladys id:0
PM2 | [2019-01-27 14:30:08] PM2 log: App name:gladys id:0 online
PM2 | [2019-01-30 17:44:03] PM2 log: App [gladys] with id [0] and pid [11725], exited with code [0] via signal [SIGINT]
PM2 | [2019-01-30 17:44:03] PM2 log: Starting execution sequence in -fork mode- for app name:gladys id:0
PM2 | [2019-01-30 17:44:03] PM2 log: App name:gladys id:0 online
PM2 | [2019-01-30 17:47:22] PM2 log: App [gladys] with id [0] and pid [15904], exited with code [0] via signal [SIGINT]
PM2 | [2019-01-30 17:47:22] PM2 log: Starting execution sequence in -fork mode- for app name:gladys id:0
PM2 | [2019-01-30 17:47:22] PM2 log: App name:gladys id:0 online
PM2 | [2019-01-30 19:28:19] PM2 log: App [gladys] with id [0] and pid [16201], exited with code [0] via signal [SIGINT]
PM2 | [2019-01-30 19:28:19] PM2 log: Starting execution sequence in -fork mode- for app name:gladys id:0
PM2 | [2019-01-30 19:28:19] PM2 log: App name:gladys id:0 online
PM2 | [2019-01-30 19:54:47] PM2 log: App [gladys] with id [0] and pid [20000], exited with code [0] via signal [SIGINT]
PM2 | [2019-01-30 19:54:47] PM2 log: Starting execution sequence in -fork mode- for app name:gladys id:0
PM2 | [2019-01-30 19:54:47] PM2 log: App name:gladys id:0 online
/home/pi/.pm2/logs/gladys-out-0.log last 15 lines:
0|gladys | To see your app, visit http://localhost:8080
0|gladys | To shut down Sails, press + C at any time.
0|gladys |
0|gladys |
0|gladys | Gladys is up to date !
0|gladys | New User connected : Marty
0|gladys | Scheduled sunrise to 2019-1-31 07:11:20.
0|gladys | Scheduled sunset to 2019-1-31 16:58:08.
0|gladys | Event : create : new Event with code : sunrise
0|gladys | Scenario : Trigger : New event : sunrise
0|gladys | Scenario : Trigger : Found 0 launchers with code sunrise.
0|gladys | Event : create : new Event with code : sunset
0|gladys | Scenario : Trigger : New event : sunset
0|gladys | Scenario : Trigger : Found 0 launchers with code sunset.
0|gladys | at pass (/home/pi/gladys/node_modules/@sailshq/express/lib/router/index.js:145:5)
0|gladys | at nextRoute (/home/pi/gladys/node_modules/@sailshq/express/lib/router/index.js:100:7)
0|gladys | at callbacks (/home/pi/gladys/node_modules/@sailshq/express/lib/router/index.js:167:11)
0|gladys | at module.exports (/home/pi/gladys/api/policies/checkToken.js:25:12)
0|gladys | at routeTargetFnWrapper (/home/pi/gladys/node_modules/sails/lib/router/bind.js:181:5)
0|gladys | at callbacks (/home/pi/gladys/node_modules/@sailshq/express/lib/router/index.js:164:37)
0|gladys | at param (/home/pi/gladys/node_modules/@sailshq/express/lib/router/index.js:138:11)
0|gladys | at _sendHeaders (/home/pi/gladys/node_modules/sails/lib/hooks/cors/to-prepare-send-headers.js:91:7)
Salut @akinari
Est ce que tu peux faire une capture d’écran de tes devices stp ?
Je n’ai aucun devices encore
J’ai essayé de créer mon 1er devices et gladys m’a dit qu’il y avait une erreur
Comment est ce que tu t’y prends ?
Ok je pense avoir trouvé ce qui cloche
Merci pour l’aide
Salut @akinari !
Cela aurait été bien que tu expliqués ta résolution pour d’autre utilisateurs :slight_smile:.
Une fois fait tu pourras ajouter le tag résolu stp ?
oui pardon @spenceur
bêtement je pensait qu’en cliquant sur créer j’accéderai à une boite de paramétrage
du coup je n’inscrivait rien dans les cases :cold_sweat:
Si tu t’es posé la question c’est que d’autre se la poseront :slight_smile:.
Il n’y a aucun soucis :slight_smile:
