Stopping Bluetooth Scan for NaN seconds
bluetooth
Quand je regarde mes logs j’ai ce message un peu surprenant :
mon config.js m’a l’air correct pourtant :
module.exports = {
canInterval : process.env.BLUETOOTH_SCAN_INTERVAL || 120000, // Interval between Bluetooth scans
scanTimeout : process.env.BLUETOOTH_SCAN_TIMEOUT || 30000, // the timeout of each bluetooth scan
gladysUrl : process.env.GLADYS_URL || ‘http://localhost:8080’, // the URL of your main Gladys Instance
token : process.env.GLADYS_TOKEN || ‘xxxxxxx’, // your gladys security token. You can find it in Gladys Dashboard “Parameters” => "Sec$
gladysHouseId : process.env.GLADYS_HOUSE_ID || 1, // the ID of the house where this Bluetooth Scanner is located
services : ‘bluetooth,miflora,xiaomiht,flowerpower’, // the name of devices services (bluetooth by default).
Une idée d’ou ca peut venir ?
