Currently the user presence feature is based on bluetooth devices.
This comes with the limitation of not being able to use bluetooth devices that are not permanently connected or broadcasting.
Could we look at either:
(1) making the mobile device pair with the raspberry pi (should then allow Gladys to recognise the presence) or
(2) making the user presence feature feature wifi-based?
Option (2) might not be great for users with multiple home networks (ie: I have a guest network, a 2.4GHz and a 5GHz network)
Just dropping this here, and may this be remembered as the first International Feature Request of Gladys
You can already trigger the user presence within the scenes. First you define the trigger of your choice (I didn’t saw any wifi or BT pairing though) and this trigger leads to the action “User seen in the house” or “User leaving the house”.
Sorry for the translation, I use the french version of Gladys
I guess you can be stated as being ‘home’ if you turn a specific light/switch ‘on’
Assuming you finally bought that mandatory NEW bridge
Else, we often create a ‘fake device’ inside the ‘MQTT’ integration.
You can then use it as the trigger for ‘being home’
Not as smart as a device detection through WiFi.
