# Unterschiedlicher Wert eines Buttons zwischen Gladys und Zigbee2MQTT
**URL:** <https://community.gladysassistant.com/t/valeur-dun-bouton-different-entre-gladys-et-zigbee2mqtt/7978>\
**Created:** [15. Februar 2023 um 17:12 UTC](https://community.gladysassistant.com/t/valeur-dun-bouton-different-entre-gladys-et-zigbee2mqtt/7978 "2023-02-15T17:12:23Z")\
**Showing post:** 11
**Author:** ![Psoy](https://gladys-assistant-community.b-cdn.net/user_avatar/community.gladysassistant.com/psoy/32/9005_2.png) [@Psoy](https://community.gladysassistant.com/u/Psoy)\
**Post date:** [16. Februar 2023 um 10:22 UTC](https://community.gladysassistant.com/t/valeur-dun-bouton-different-entre-gladys-et-zigbee2mqtt/7978/11 "2023-02-16T10:22:37Z")
> [@Sonoff SNZB-01 Taster](https://community.gladysassistant.com/t/bouton-sonoff-snzb-01/6812/8):
> Je viens de m’inscrire sur Github (username : JPLalv), mais je n’ai pas su comment formuler une PR pour Gladys. Mais peu importe, dans [atrovato](https://github.com/atrovato) [Fix & clean NaN device state , j’ai trouvé ceci : // Case for Button devices case 'click': { switch (value) { case 'single': result = BUTTON\_STATUS.CLICK; break; case 'double': result = BUTTON\_STATUS.DOUBLE\_CLICK; break; case 'hold': result = BUTTON\_STATUS.LONG\_CLICK; break; default: result =…
Hier findest du einen Überblick, wie das codiert ist, denke ich :zwinkern:
_[View the full topic](https://community.gladysassistant.com/t/valeur-dun-bouton-different-entre-gladys-et-zigbee2mqtt/7978)._
