Hello @MathieuA,
voila les logs après avoir ajouté le console.log dans le module Z-wave
> Zwave module: Setting the product id param
0|gladys | Zwave module: Setting the com name param
0|gladys | Zwave module: Running connection
0|gladys | gladys.utils.sqlUnique was not able to find element
0|gladys | Query = "
0|gladys | SELECT devicetype.id
0|gladys | FROM device
0|gladys | JOIN devicetype ON (device.id = devicetype.device)
0|gladys | WHERE devicetype.identifier = ? AND device.service = ?;
0|gladys | "
0|gladys | Params = "["1-32-0","zwave"]"
0|gladys | Zwave module: Fail to save deviceState : Error: NotFound
0|gladys | "
0|gladys | Params = "["5-38-0","zwave"]"
0|gladys | "
0|gladys | Params = "["6-38-0","zwave"]"
0|gladys | "
0|gladys | Params = "["7-37-0","zwave"]"
0|gladys | { device:
0|gladys | { name: 'Static PC Controller',
0|gladys | protocol: 'zwave',
0|gladys | service: 'zwave',
0|gladys | identifier: 1 },
0|gladys | types:
0|gladys | [ { name: 'Basic',
0|gladys | type: 'byte',
0|gladys | identifier: '1-32-0',
0|gladys | sensor: false,
0|gladys | unit: '',
0|gladys | min: 0,
0|gladys | max: 255,
0|gladys | display: false } ] }
0|gladys | Zwave module : Device of node 1 created
0|gladys | "
0|gladys | Params = "["6-37-0","zwave"]"
0|gladys | "
0|gladys | Params = "["6-50-0","zwave"]"
0|gladys | "
0|gladys | Params = "["6-113-0","zwave"]"
0|gladys | "
0|gladys | Params = "["6-113-1","zwave"]"
0|gladys | "
0|gladys | Params = "["6-50-8","zwave"]"
0|gladys | "
0|gladys | Params = "["6-50-32","zwave"]"
0|gladys | "
0|gladys | Params = "["6-113-2","zwave"]"
0|gladys | "
0|gladys | Params = "["6-113-11","zwave"]"
0|gladys | "
0|gladys | "
0|gladys | "
0|gladys | "
0|gladys | "
0|gladys | "
0|gladys | "
0|gladys | { device: { name: '', protocol: 'zwave', service: 'zwave', identifier: 6 },
0|gladys | types:
0|gladys | [ { name: 'Switch',
0|gladys | type: 'binary',
0|gladys | identifier: '6-37-0',
0|gladys | min: 0,
0|gladys | max: 1,
0|gladys | display: false },
0|gladys | { name: 'Level',
0|gladys | identifier: '6-38-0',
0|gladys | min: 0,
0|gladys | { name: 'Bright',
0|gladys | type: 'button',
0|gladys | identifier: '6-38-1',
0|gladys | min: 0,
0|gladys | max: 0,
0|gladys | { name: 'Dim',
0|gladys | identifier: '6-38-2',
0|gladys | min: 0,
0|gladys | max: 0,
0|gladys | { name: 'Unknown',
0|gladys | type: 'decimal',
0|gladys | identifier: '6-50-0',
0|gladys | sensor: true,
0|gladys | min: 0,
0|gladys | max: 0,
0|gladys | { name: 'Power',
0|gladys | identifier: '6-50-8',
0|gladys | unit: 'W',
0|gladys | min: 0,
0|gladys | max: 0,
0|gladys | { name: 'Exporting',
0|gladys | identifier: '6-50-32',
0|gladys | min: 0,
0|gladys | max: 1,
0|gladys | { name: 'Alarm Type',
0|gladys | identifier: '6-113-0',
0|gladys | min: 0,
0|gladys | { name: 'Alarm Level',
0|gladys | identifier: '6-113-1',
0|gladys | min: 0,
0|gladys | { name: 'SourceNodeId',
0|gladys | identifier: '6-113-2',
0|gladys | min: 0,
0|gladys | { name: 'Power Management',
0|gladys | identifier: '6-113-11',
0|gladys | min: 0,
0|gladys | "
0|gladys | "
0|gladys | "
0|gladys | Zwave module : Error while creating device of node 6 : [Error (E_VALIDATION) 1 attribute is invalid] Invalid attributes sent to Device:
0|gladys | • name
0|gladys | • "required" validation rule failed for input: ''
0|gladys | Specifically, it threw an error. Details:
0|gladys | undefined
Sur jeedom j’ai intégré une prise electrique Zwave, donc dans les logs, ça doit aussi apparaitre je pense.
Après une semaine de test sur jeedom, mon matos fonctionne correctement. donc je dirais que ca vient de Gladys. Je programme avec javascript et jquery au boulo, donc si besoin de mettre les mains dans le code, je devrais être apte. Si ca peut aider la communauté je suis partant
