Gladys Assistant OS: install Gladys on a mini-PC with a simple USB key 🚀
I tested it and overall it works very well. I have a few comments:
  • I chose France as the country at the beginning, but then in two places I had a mix of French and English:
  • I know the documentation says in two places that the mini-PC must be connected to the network via Ethernet. But I made a mistake and didn’t do it… The installation then proceeds completely until this screen appears indicating that the Ethernet connection is missing:
I tried plugging in the cable, but it was too late; a configuration was probably not done correctly. I restarted the entire procedure with the cable plugged in and everything ended well.
Perhaps the absence of an Ethernet network should be detected before starting the installation?
