Hello @LM1LC3N7, I am particularly interested in this Ajax alarm system integration and thought I had managed to configure it according to the described method. But it must be said that I have certainly made a mistake because the data I need is not being sent to Gladys, i.e. the status of the alarm state (arm or disarm), the group and the last event.
The alarm status remains at “disarm”
I have this information in the supervision tab
And here are the latest logs
[2026-11-14T06:21:07.302Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-11-14T06:21:17.700Z] [WARN] Lost the SIA receiver, reconnecting
[2026-11-14T06:21:18.742Z] [INFO] Starting the Ajax Systems (SIA DC-09) integration...
[2026-11-14T06:21:19.020Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-11-14T06:21:19.309Z] [INFO] Connected to the SIA receiver
[2026-11-14T11:38:05.943Z] [INFO] Alarm and fault memory cleared from the configuration screen
[2026-11-14T11:41:32.956Z] [WARN] A panel reports with account 000, which is not in the configuration: add it there
[2026-11-14T11:42:13.549Z] [INFO] Alarm and fault memory cleared from the configuration screen
[2026-11-14T11:42:33.453Z] [WARN] A panel reports with account 000, which is not in the configuration: add it there
[2026-11-14T11:43:35.555Z] [WARN] A panel reports with account 000, which is not in the configuration: add it there
[2026-11-14T11:44:21.719Z] [WARN] [gladys-sdk] connection to Gladys lost (close code 1006)
[2026-11-14T11:44:21.719Z] [WARN] [gladys-sdk] not connected to Gladys (ws://172.30.0.1:80), retrying in 1000 ms (attempt 1)
[2026-11-14T11:44:22.930Z] [INFO] Starting the Ajax Systems (SIA DC-09) integration...
[2026-11-14T11:44:23.231Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-11-14T11:44:23.533Z] [INFO] Connected to the SIA receiver
A helping hand would not be unwelcome.
Thanks in advance
