External integration - Bbox (Bouygues Telecom, local)
Hi everyone! :waving_hand:
Last of the French boxes: here is the Bbox from Bouygues Telecom in Gladys, locally, via the official box API.
What it does
  • :satellite_antenna: The line: fiber, VDSL2 or ADSL, synchronized or not, synchronized speeds.
  • :globe_with_meridians: Internet: connected or not, instantaneous speeds for upload and download, public IP, IPv6.
  • :antenna_bars: Wi-Fi 2.4 GHz, 5 GHz and guest, which can also be turned on and off from Gladys.
  • :telephone: Missed calls, if your Bbox provides them.
  • :eyes: Connected devices: presence by MAC address, for the devices you choose.
  • :1234: Number of connected devices, uptime, temperature, model and firmware.
  • :clapper_board: Three scene triggers: « Internet Connection Lost Â», « Internet Connection Restored Â» and « Missed Call Â», with the number.
  • :puzzle_piece: A « Bbox Â» widget: live speeds, connected devices, status, and a guest Wi-Fi button.
  • In French, English, German and Spanish :wink:
The cool thing
Friends arrive → a button on the dashboard turns on the guest Wi-Fi, and a scene turns it off at midnight :tada:
Missed call while you’re in the garden → notification with the number :telephone_receiver:
Internet connection lost → message on the phone in 4G, so you don’t discover it in the evening :sweat_smile:
Installation
:warning: Gladys 5.1 minimum.
:light_bulb: It arrives in the store during the day. In a hurry? Integrations → Install from GitHub, with the address GitHub - guim31/gladys-bbox: Bouygues Telecom Bbox status (line, WAN, Wi-Fi, connected devices) for Gladys Assistant, local API · GitHub
  1. In the configuration, indicate the Bbox address (192.168.1.254 by default) and its administrator password.
  2. Click on Test the connection.
  3. Discovery tab: add the Bbox, and the devices whose presence you want to track.
Honest small reservations
  • :warning: Beta, developed without a Bbox. Tests were done on real Bbox responses (F@st5330b, F@st5688b) taken from public projects, notably pybbox (MIT, thanks!).
  • The Bbox certificate is properly verified: the integration does not cut TLS security silently.
  • The Bbox protects against repeated connections: a wrong password is not retried in a loop.
@cicoub13, you told me you had a Bbox: your turn to play :wink: And anyone with a Bbox is welcome to test :folded_hands:
Like the previous ones, developed with Claude Code :robot:. Independent project, not affiliated with Bouygues Telecom.
Repository: GitHub - guim31/gladys-bbox: Bouygues Telecom Bbox status (line, WAN, Wi-Fi, connected devices) for Gladys Assistant, local API · GitHub
Configuration :white_check_mark:
Widget and devices :white_check_mark:
I’ll test on my side (when the missus isn’t working on the Wi-Fi):
  • turn guest Wi-Fi off/on
  • turn Wi-Fi off/on
  • test device presence
Thanks for this integration, it also works for me (bbox wifi 6E).
Would it be possible to add some widget settings? (to choose whether to display all lines or not)
Thanks @Damien, glad it also works on Wi-Fi 6E! Version 1.1.0 adds a setting to the widget, Lines to display: you check the tiles and lines you want to keep (throughput, connected devices, Internet, line, IPv4, Wi-Fi, missed calls, guest Wi-Fi button
). If left empty, the widget displays everything, as before.
Update from Gladys, then modify your widget to choose your lines :slight_smile:
:scream::scream: You’ll tell Claude that we say LE wifi :rofl:
In my opinion Claude says « the WiFi connection Â» but it bothers me too :face_savoring_food:
