I’d love to, but I’m not at all « ripe » to understand everything!! I’m already trying to figure out how GitHub works…
It was the same for me not long ago ![]()
And by watching Pierre Gilles’ videos, I’m getting there little by little ![]()
@prohand
Is it possible to delete/hide stations that don’t have a particular fuel?
I’m on E85 and stations without E85 show this -:
• Système U - xxx (0.8 km) — E85 (Superethanol): -
• 5 ALLEE DE L’ECONOMIE - xxx (0.8 km) — E85 (Superethanol): 0.824 EUR/L
• TotalEnergies Access - xxx (6.7 km) — E85 (Superethanol): 0.839 EUR/L
• TotalEnergies - xxx (7.9 km) — E85 (Superethanol): 0.839 EUR/L
• Auchan - xxx (8.2 km) — E85 (Superethanol): 0.839 EUR/L
• Système U - xxx (8.5 km) — E85 (Superethanol): -
• TotalEnergies - xxx (8.9 km) — E85 (Superethanol): -
• Carrefour - xxx (9.0 km) — E85 (Superethanol): -
… +12
EDIT: My mistake, they don’t appear in Discovery, so perfect ![]()
Hello @prohand,
Thank you for this integration ![]()
I do have a comment though: at least 4 stations are available around my place, but when I test the integration, none appear (though I don’t live in the middle of nowhere…):
[2026-08-10T07:39:25.435Z] [INFO] Starting the fuel prices integration...
[2026-08-10T07:39:26.839Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:8082)
[2026-08-10T07:39:27.143Z] [INFO] 0 station device(s) tracked
[2026-08-10T07:39:27.146Z] [WARN] No postal code configured yet: nothing to discover
[2026-08-10T07:39:27.149Z] [INFO] [refresh] Prices will be refreshed every 3600s
[2026-08-10T07:41:07.825Z] [INFO] onConfigUpdated -> new configuration received
[2026-08-10T07:41:07.827Z] [INFO] [refresh] Prices will be refreshed every 3600s
[2026-08-10T07:41:08.278Z] [WARN] [provider-fr] No station found in postal code 67750: cannot widen the search around it
[2026-08-10T07:41:08.338Z] [INFO] [devices] Discovery: 0 station(s) around 67750, 1 device(s) published for Diesel, SP95, SP98, E10 (SP95-E10)
[2026-08-10T07:41:10.772Z] [WARN] [provider-fr] No station found in postal code 67750: cannot widen the search around it
In doubt, the integration was restarted, but no improvement…
Any ideas?
Thanks in advance,
Have a nice day,
Jean
Thanks for reporting the issue.
The new version 1.0.3 that just came out should fix your problem
I also took the opportunity to fix a bug I was encountering as well and here is Claude’s feedback on the fix:
XXXXX — no stations, regardless of radius
The center of the search circle was the average position of stations with this postal code. « NOM VILLE » has none in the national feed → no center →
src/countries/france.js:125simply skipped the « radius » step. Increasing the radius couldn’t change anything: there was no circle to expand.When the feed doesn’t know the location of the postal code, it is now geocoded via the National Address Database (
src/countries/franceGeocode.js, official, no key). Best effort and cached, in the spirit offranceNames.js: an unreachable geocoder costs stations around the postal code, never those that are inside.XXXXX — only certain stations (NOM STATION)
The radius query was limited to 300 records, and the API responds to
within_distancein the order of the dataset — that is, by station ID, that is, by postal code. A truncated circle therefore does not lose the furthest stations, it loses the highest postal codes: around Lyon, XXXXX and XXXXX fall after 69000/69100. And increasing the radius worsened the problem, by adding competitors to the same truncated response.The search now goes through concentric circles starting from 5 km, doubling until the configured radius, and stops at the first complete circle containing at least
limitstations — this circle then necessarily contains the closest ones. In the city it’s also cheaper than before: a query from a small circle instead of three pages of a large one.
I have indeed selected two fuels SP95 and SP98, but I only have one SP98 device and one price.
Not a big deal in itself as at Total it’s the same for now except they are out of 98 and correctly display ‹ no recent value ›, which makes sense. I assume that if I had SP95, I would have a device value.
Could you send me your postal code in a private message please so I can reproduce it ![]()
93160
Total energy avenue Médéric where I usually go…
Thanks ![]()
Here’s Claude’s feedback: (I also fixed an issue reported directly on Github at the same time)
Issue #10 — « Cloud » tag
- The Local/Cloud tag comes from the
transportsfield in the manifest (verified in the Gladys frontend:IntegrationCategory.jsx→integration.cloud←manifest.transports).- Added
"transports": ["cloud"]ingladys-assistant-integration.json.localnot declared on purpose: it would display the « Prefer local connection (LAN) » toggle, which is not relevant here.- Manifest validated against the store indexer’s schema →
valid: true. Test added in test/manifest.test.js.SP95 invisible on TotalEnergies
This is not a code bug, it’s the data. Verified live on open data:
- 4835 stations publish a SP98 price and no SP95 price.
- Provider test on 92100/Paris: all TotalEnergies have
sp95=null,sp98/e10filled.- TotalEnergies have replaced SP95 with E10 (SP95-E10). As a (station, fuel) pair without a price is never published, no SP95 device is offered.
What I changed to make it not look like a bug:
- « Preview nearby stations »:
SP95: not soldinstead of a simple-, in FR and EN (with the space before the colon in French).- If no found station sells a checked fuel: a line announces it and suggests E10 as a replacement for SP95.
- Note added in the description of the « Fuel type » field and in docs/fr.md / docs/en.md (Troubleshooting section).
Available in version 1.0.5
OK I’ve installed version 1.0.5;
I’ll wait for the situation to change because what’s in my station list has evolved and the three total would be out of fuel…
Actually, you need to select SP95-E10 in the configuration section in addition to SP95, as Total only sells SP95-E10.
OK but this evening I added diesel here is the preview copy…
3 station(s) around 93160:
• TotalEnergies - Noisy-le-Grand (0.4 km) — Diesel: not sold, SP98: not sold, E10 (SP95-E10): not sold
• TotalEnergies - Noisy-le-Grand (1.2 km) — Diesel: 2.250 EUR/L, SP98: not sold, E10 (SP95-E10): not sold
• TotalEnergies - Noisy-le-Grand (1.6 km) — Diesel: 2.250 EUR/L, SP98: not sold, E10 (SP95-E10): not sold
None of these stations sell SP98.
None of these stations sell E10 (SP95-E10).
Actually if out of stock the display of ‹ no recent value › for SP98 was correct because I went by yesterday afternoon and the price was 9.999 (out of stock).
This is fixed in version 1.0.6:
What it does
- The name remains short as long as it is unique:
Esso - Noisy-le-Grand - Diesel.- If two stations have the same sign and the same town, the street is inserted:
TotalEnergies - 33 Av. Médéric - Noisy-le-Grand - DieselTotalEnergies - 104/106 AV MEDERIC - Noisy-le-Grand - Diesel- If even the street is identical (motorway service area, 2 directions), the national ID is added at the end.
- The street is abbreviated (Avenue → Av., Boulevard → Bd, Route → Rd…) and cut to 28 characters.
Limitation to know
The 2 devices already created keep their current name (Gladys never rewrites a chosen/existing name). Two options:
- rename them manually in Devices (the simplest, keeps the history);
- delete them and add them again from Discovery → new detailed name, but price history lost.
I just set up 1.0.6.
Renamed manually: OK, it’s done, very well.
New preview:
• TotalEnergies - Rue du Centre Centre Reg… - Noisy-le-Grand (0.4 km) — Diesel: 2.250 EUR/L, SP98: 1.990 EUR/L, E10 (SP95-E10): 1.990 EUR/L
• TotalEnergies - 33 Av. Médéric - Noisy-le-Grand (1.2 km) — Diesel: 2.250 EUR/L, SP98: not sold, E10 (SP95-E10): not sold
• TotalEnergies - 104/106 AV MEDERIC - Noisy-le-Grand (1.6 km) — Diesel: not sold, SP98: not sold, E10 (SP95-E10): not sold
Add the ones you want from the Discovery tab.
Personally, I have two TotalEnergies in the same street, which is good for testing.
The Mont d’est station has SP98.
This would mean that a device can only be constituted if the fuel is available, so in the current period it is necessary to scan regularly to obtain all the devices.
I continue to monitor…
This has been fixed in 1.0.7
The issue
- The feed does not publish prices in two cases: the station does not sell this fuel, or it is out of stock. The integration read both as « not sold ».
- Verified on your stations:
93160001and93160009(Noisy-le-Grand) are temporarily out of stock on diesel/SP98/E10 — not « not sold ».What has changed
- Reading stockouts from the feed: columns
sp98_rupture_type/_start(v2) and nestedrupturetable (old model).temporary(or empty type) → out of stock;definitive→ not sold; a published price always takes precedence.- New src/availability.js: 3 states per fuel (
available/out_of_stock/not_sold).- Discovery: a station that is out of stock is now offered (the price returns with the truck), no need to go back to Discovery.
- Device: the text feature displays « Out of stock since 18/09/2026 at 08:09 », the last known price remains on the curve.
- « Search for stations » button: « SP98: out of stock » instead of « SP98: not sold », and the note « no station sells… » becomes a stockout note when applicable.
- FR/EN Docs + CLAUDE.md updated.
Version 1.0.7:
• TotalEnergies - Rue du Centre Centre Reg… - Noisy-le-Grand (0.4 km) — Diesel: 2.250 EUR/L, SP98: out of stock, E10 (SP95-E10): out of stock
• TotalEnergies - 33 Av. Médéric - Noisy-le-Grand (1.2 km) — Diesel: out of stock, SP98: out of stock, E10 (SP95-E10): out of stock
• TotalEnergies - 104/106 AV MEDERIC - Noisy-le-Grand (1.6 km) — Diesel: out of stock, SP98: out of stock, E10 (SP95-E10): not sold
SP98 is out of stock at all these stations: the pumps are available, the price will return with the fuel.
E10 (SP95-E10) is out of stock at all these stations: the pumps are available, the price will return with the fuel.
Much more readable… great.
However, E10 (SP95-E10) not sold at 104/106 avenue Médéric surprises me. I’ll go check in person.
I’ll keep following up
Yes, please keep me updated if you find a bug ![]()
Thanks
Good evening @prohand and thank you for this very useful integration at this time.
I noticed that a room needs to be specified for each product per station. Is it planned to find the information in a dashboard?
I don’t understand what you mean by « a room for each product per station »
V2 comes with widgets but there’s apparently a bug that I just posted on the forum:
Version 2.0.5 is out with widgets, triggers, and actions ![]()
