Hi, so when I let Gladys installation/setup occur, it then asks for my default Rasbian username and password. After this it drops me at the command line. What am I supposed to do next? The PI isn’t picked up by the router so the web interface doesn’t load.
I also tried unsuccessfully to add my wifi details into the wpa_supplicant.conf file but that didn’t seem to do much good either.
Sorry, I’m not sure I understood. I tried auto wlan0 on the pi command line but that didn’t work, and then hooked the SD card to my PC but have no folder structure live you’ve specified.
Could you please clarify how and where I input these commands?
The /etc/network/interface file is accessible from your ssh session. You have to add the line that I mentionned.
I rewritted my gladys image to reproduce the issue and validate this fix but…without success. My new gladys image works perfectly without any modification
So, could you try this :
rewritte Gladys image on your SD card
Put the wpa_supplicant.conf file at the root of your sd card
