I am submitting a problem encountered during the integration of a Home Assistant Connect ZBT-2 key with Zigbee2MQTT - Gladys v5.3.5.
When in Gladys I select the Home Assistant Connect ZBT-2 model in the Zigbee2MQTT integration configuration, the service fails to start with the following error in the log: Error: Failed to start EZSP layer with status=HOST_FATAL_ERROR.
The configuration file /var/lib/gladysassistant/zigbee2mqtt/z2m/configuration.yaml contains in the serial section:
port: /dev/ttyACM0
adapter: ember
After some research on the net, I manually add to the configuration file the parameters baudrate: 460800 and rtscts: true
serial:
port: /dev/ttyACM0
adapter: ember
baudrate: 460800
rtscts: true
et I manually restart the Zigbee2MQTT docker container.
Result OK: Zigbee2MQTT starts and the key is operational.
However, as soon as I stop and start Zigbee2MQTT from the Gladys UI or I restart the server, Zigbee2MQTT does not start, the same previous error is found in the log.
et the configuration file contains:
port: /dev/ttyACM0
adapter: ember
The baudrate and rtscts parameters added manually have been overwritten.
Is it possible to permanently add these 2 parameters to the Home Assistant Connect ZBT-2 profile applied by Gladys?
