# Audit: compatibility and feature parity with the Home Assistant Hue integratio…n
## Context
- **Audited:** `gladys-philips-hue` v2.0.3, commit [`5de09d7`](https://github.com/cicoub13/gladys-philips-hue/tree/5de09d7e012f56cf3978cc5f32c05a611ee73230).
- **Compared with:** the Home Assistant core `hue` integration at [`7deeb95`](https://github.com/home-assistant/core/tree/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue) (2026-11-24), which uses `aiohue` 4.9.2, and Gladys core 5.3.5 for what Gladys can represent.
- **Method:** I read the code; I did not run it or test it on hardware. Facts about bridges come from Signify developer news and recent community reports, linked in the references. Items marked *to confirm on hardware* still need a test on a real bridge.
## TL;DR
- **The foundations are solid.** Pairing is robust, discovery only offers real bridges, credentials are handled carefully, and the integration recovers on its own after outages. On a few points it is ahead of Home Assistant (see §5).
- 🔴 **One urgent bug.** Bridge firmware 1.78, being rolled out now, blocks plain HTTP. Almost every existing installation paired its bridge over HTTP, and the integration cannot switch it to HTTPS without a new pairing. Once the bridge updates, every read and every command fails (§1).
- **Parity with Home Assistant is still far off, for structural reasons:**
1. The integration uses only the v1 API. Signify has frozen it, and everything new since 2021 is v2-only: effects, gradients, smart scenes, contact sensors, Tap Dial rotation, MotionAware, and the Bridge Pro features.
2. It exposes **lights only.** Home Assistant also exposes rooms and zones, scenes, motion, light level, temperature, contact and tamper sensors, battery, remotes and buttons, and configuration switches.
3. It **polls** the bridge (every 60 s by default). Home Assistant gets state changes pushed by the v2 event stream on BSB002/BSB003 bridges.
## 1. 🔴 Urgent: bridges paired over HTTP break when HTTP is blocked
**What changed on the bridge side**
- On 2025-06-04, Signify announced that, because of RED compliance, firmware released from 1 August no longer supports HTTP: "the Hue API should be accessed exclusively over TLS".
- The Hue Bridge Pro (BSB003) has only ever accepted HTTPS.
- On 2026-11-21, a BSB002 on firmware `1978688000` (API `1.78.0`) was reported answering plain HTTP with **`403`** and `unauthorized user - HTTP access is blocked` ([aiohue issue 708](https://github.com/home-assistant-libs/aiohue/issues/708)).
**What happens in the integration**
- The scheme is chosen once, when the bridge is identified, with HTTP tried first ([`identify.js#L76`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/identify.js#L76)). It is then stored and reused forever ([`bridge.js#L76`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/bridge.js#L76)).
- So every bridge paired while HTTP still worked is stored as `http`. That includes bridges paired by 1.0.x/1.1.x, which stored no scheme at all and fall back to `http`.
- After the firmware update:
- `getLights()` and `setLightState()` fail with HTTP 403 ([`bridge.js#L135`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/bridge.js#L135)), so every command fails and states stop updating.
- The bridge is counted as unreachable ([`manager.js#L175`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/manager.js#L175)), and the status tells the user to "check that it is powered on and on the same network", which sends them looking in the wrong place.
- The background resync keeps retrying with the same scheme, without end.
**Workaround for users today:** press the link button, then click **Pair bridge**.
- Identification falls back to HTTPS, and `upsert` is keyed by bridge id, so the external_ids are kept.
- The downside is that it leaves an orphan user on the bridge.
**Suggested fix (patch release):**
1. When a bridge stored as `http` returns this 403 (or refuses the connection on port 80), retry **with the same username over HTTPS**.
- The application key is not tied to the transport, so no link-button press is needed.
- Check the certificate (CN = bridge id), pin it, and persist `scheme: 'https'`.
2. Make identification try **HTTPS first**, with HTTP only as a fallback. The round v1 bridge (BSB001) never got HTTPS.
3. Add a changelog line and a troubleshooting entry to the docs.
**Compared with Home Assistant:**
- HA's v2 entries already use HTTPS, so they keep working after this firmware update.
- *Pairing* a new bridge on this firmware is currently broken in HA (aiohue issue 708 is still open).
- This integration's HTTPS fallback at identification is therefore ahead of HA for new pairings. Only the migration of existing pairings is missing.
## 2. Compatibility matrix by bridge generation
| Bridge | This integration (2.0.3) | Home Assistant |
| **BSB001** (round, v1, end of support 2020) | ✅ v1 over HTTP, polling | ✅ v1, polling every 5 s |
| **BSB002**, firmware still accepting HTTP | ✅ v1 over HTTP, polling every 10–60 s | ✅ v2 over HTTPS, push (event stream) |
| **BSB002**, firmware ≥ 1.78 (HTTP blocked) | ⚠️ new pairing works (HTTPS fallback)<br>❌ existing pairings stop working until re-paired (§1) | ✅ existing entries keep working<br>⚠️ new pairing currently broken (aiohue issue 708) |
| **BSB003** Hue Bridge Pro | ⚠️ should pair over HTTPS: other v1 clients report that v1 works over HTTPS on the Pro (*to confirm on hardware*)<br>❌ migrating from a BSB002 orphans every device (§4.6)<br>❌ MotionAware (v2-only) | ✅ including automatic detection of a BSB002 → BSB003 migration, and MotionAware |
| **Several bridges** (e.g. a BSB002 and a Pro) | ⚠️ discovery can miss the Pro (§4.8) | ✅ |
## 3. Feature parity
| Feature | Home Assistant | This integration | Can Gladys represent it? |
| On/off, brightness, color, white temperature | ✅ | ✅ | ✅ |
| Light powered off at the wall | shown as *unavailable* (`zigbee_connectivity` in v2, `reachable` in v1) | ❌ stays **ON** (§4.1) | ✅ `GLADYS_TRANSPORT = unreachable` via `publishTransports` |
| Changes made outside Gladys | instant (v2 event stream) | after up to 10–60 s (default 60 s) | ✅ |
| Effects: candle, fire, prism, sparkle, opal, glisten, underwater, cosmos, sunbeam, enchant, plus sunrise/sunset | ✅ | ❌ | ✅ `light` / `effect-mode` + `supported_options` |
| Transition, flash / identify | ✅ | ❌ | partly |
| Gradient lights, per segment | ✅ (one light entity per segment, added recently) | ❌ (single color) | ✅ one color feature per segment |
| Rooms and zones as one light | ✅ (`grouped_light`) | ❌ | ✅ one light device per group |
| Hue scenes | ✅ scene entities<br>✅ `hue.activate_scene` (dynamic palette, speed, brightness, transition)<br>✅ active-scene select per room | ⚠️ scene action by name and room, static recall only | — |
| Smart scenes (natural light, time-based) | ✅ | ❌ (v2-only) | — |
| Motion: sensors, grouped motion, MotionAware areas | ✅ | ❌ | ✅ `motion-sensor` |
| Light level, temperature | ✅ | ❌ | ✅ `light-sensor` (lux), `temperature-sensor` |
| Battery | ✅ | ❌ | ✅ `battery` (badge on the Devices page) |
| Contact and tamper (Secure contact sensor) | ✅ | ❌ (v2-only) | ✅ `opening-sensor`, `tamper` |
| Buttons and remotes: dimmer, smart button, wall switch module, Tap Dial rotation, bell | ✅ event entities + device triggers | ❌ | ✅ `button` / `click` with `BUTTON_STATUS` (click, double click, long press/release, hold, rotate left/right) |
| Enable/disable motion and light sensors, Hue automations, MotionAware | ✅ switches | ❌ | ✅ `switch` |
| Zigbee connectivity, entertainment area active | ✅ diagnostics | ❌ | partly |
| Bridge IP change | ✅ host updated from zeroconf | ❌ needs a new pairing (§4.7) | ✅ |
| Bridge replacement or migration to Bridge Pro | ✅ | ❌ (§4.6) | ✅ |
| Request throttling | ✅ v1: 1 request per 250 ms, retries with growing backoff (up to 25)<br>✅ v2: at most 3 connections, backoff | ⚠️ none, 1 retry after 400 ms (§4.5) | — |
## 4. Detailed findings
### 🟠 4.1 A light powered off at the wall stays "on" in Gladys
[`mapping.js#L279`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/mapping.js#L279) only reads `state.on` and never reads `state.reachable`.
- When a bulb is cut at the wall, the bridge keeps its last state (`on: true`) with `reachable: false`. So Gladys shows it **on** indefinitely, and scene conditions such as "if the light is on" are wrong.
- This is the most common Hue complaint, and the one HA handles in both APIs:
- v1: `reachable` ([`v1/light.py#L497`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/v1/light.py#L497));
- v2: `zigbee_connectivity` ([`v2/entity.py#L109`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/v2/entity.py#L109)).
- HA also offers an option to ignore availability for lights that report it badly.
**Suggestion:** publish `GLADYS_TRANSPORT: unreachable` for the light (`gladys.publishTransports`, shown as a pill on the Devices page), and `local` once it is reachable again. Possibly also publish on/off = 0 while it is unreachable, since the bulb is physically off.
### 🟠 4.2 State is polled, not pushed
The default refresh interval is 60 s, with 10 s as the minimum ([`config.js#L20`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/config.js#L20)).
- A change made with a Hue dimmer, the Hue app or a Hue automation reaches Gladys up to a minute later. Scenes triggered by "light turned on/off" fire late or miss short changes.
- HA declares `iot_class: local_push`: on BSB002/BSB003 bridges it subscribes to the v2 event stream, `GET https://<ip>/eventstream/clip/v2` with the `hue-application-key` header ([`aiohue events.py#L190`](https://github.com/home-assistant-libs/aiohue/blob/edfdc8a8e320d0f30628f882c0902b4ab0595d19/aiohue/v2/controllers/events.py#L190)).
- **The v1 username already stored is a valid v2 application key**, so the stream can be added without a new pairing.
- Keep polling as a fallback, and for BSB001. HA's v1 code polls every 5 s; one `GET /lights` per bridge every few seconds is cheap.
- `publishChangedStates` already keeps the Gladys 300 states/min budget under control. Coalesce bursts (a held dimmer button) per feature before publishing.
### 🟠 4.3 Only lights are exposed
The integration reads `/lights` only. All the accessories in the table in §3 are missing: sensors, remotes, contact sensors, MotionAware and so on. Gladys already has a category for each of them.
Two implementation notes:
- **Buttons must be published with `publishState`, not `publishChangedStates`.** Two identical clicks in a row are two events, and the second one would be dropped as "unchanged".
- Contact sensors, Tap Dial rotation, bell buttons and MotionAware exist **only in v2**. Motion, light level, temperature and dimmer switches are also in v1 (`/sensors`), but without push their value is poor: a motion sensor read every 60 s is not usable.
### 🟠 4.4 Rooms and zones are not exposed (`grouped_light`)
- HA creates one light entity per Hue room and zone ([`v2/group.py#L84`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/v2/group.py#L84)), plus a select per room that lists its scenes and shows the active one ([`v2/select.py#L86`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/v2/select.py#L86)).
- A group command is a single Zigbee broadcast: all lights change at the same time (no "popcorn" effect), and it costs one request instead of N.
- This matters even more in Gladys: the "turn off the lights" scene action calls `setValue` **for every light in parallel** (`server/lib/scene/scene.actions.js`, `ACTIONS.LIGHT.TURN_OFF`). See §4.5.
### 🟠 4.5 No request throttling
- `setValue` sends a `PUT` immediately ([`manager.js#L520`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/manager.js#L520)), with a single retry after 400 ms on 429/503 ([`bridge.js#L33-L34`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/bridge.js#L33-L34)).
- A Gladys scene acting on 15 lights sends 15 concurrent requests. The bridge refuses more than about 3 at once, and Signify recommends about 10 light commands/s (and about 1 group command/s). Commands end up lost.
- aiohue spaces out v1 requests (one every 250 ms, [`v1/__init__.py#L22`](https://github.com/home-assistant-libs/aiohue/blob/edfdc8a8e320d0f30628f882c0902b4ab0595d19/aiohue/v1/__init__.py#L22)), caps v2 at 3 connections ([`v2/__init__.py#L217`](https://github.com/home-assistant-libs/aiohue/blob/edfdc8a8e320d0f30628f882c0902b4ab0595d19/aiohue/v2/__init__.py#L217)), and retries 429/503 with a growing backoff.
**Suggestion:** one queue per bridge (about 10 requests/s, at most 3 in flight), and several retries with backoff on 429/503 within the command's timeout. Grouping simultaneous commands into a group action (§4.4) is the next step.
### 🟠 4.6 Replacing a bridge or migrating to a Bridge Pro orphans every device
- The external_ids include the bridge id: `platformId = <bridge id>-<light uniqueid>` ([`manager.js#L192`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/manager.js#L192)).
- After the official BSB002 → BSB003 migration, which Signify has supported since 2025 including multi-bridge migration since 2025-12-15, the bridge id and IP change:
- every light shows up again as a **new** device in the Discovery tab;
- the devices already created (with their scenes, rooms and history) stop working;
- the old bridge stays in `bridges.json` **forever**, because there is no action to forget a bridge ([`store.js`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/store.js) has no `remove`). The status then shows "1 Hue bridge unreachable" for good, and the resync retries without end.
- HA detects a migrated bridge: it tries the existing key on the new bridge and moves the entry to it ([`config_flow.py#L303`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/config_flow.py#L303)).
**Suggestion:** reuse the existing `platformKey` mechanism.
1. When a new bridge's lights match, by `uniqueid` (a Zigbee MAC, globally unique), the lights of a stored bridge, give the new bridge that bridge's `platformKey || id`, then drop the old entry.
2. Before asking for the link button, try the stored key on the new bridge.
3. Add a "Forget bridge" action.
### 🟡 4.7 A bridge whose IP changed needs a new pairing, and the docs say otherwise
- Bridges are addressed by their stored IP. Only a new pairing updates it, which means pressing the link button and creating a new user on the bridge.
- The docs say: "check that the bridge did not change IP address (fix it in your box), then run a discovery again" ([`docs/fr.md#L117-L118`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/docs/fr.md#L117-L118), same in `en.md`). But **Discover bridges** does not update the stored IP.
- HA updates the host automatically when zeroconf sees the bridge at a new address ([`config_flow.py#L249`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/config_flow.py#L249)).
**Suggestion:** when a paired bridge is unreachable, or when **Discover bridges** runs:
1. Match the discovered bridges by `bridgeid`.
2. Update the stored IP (and the `unreachable` set, which is keyed by IP), keeping the same username.
3. Fix the docs.
### 🟡 4.8 Discovery stops at the first method that finds something
- SSDP → mDNS → N-UPnP: each method only runs if the previous one found nothing ([`discovery.js#L182-L195`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/discovery.js#L182-L195)).
- Signify has deprecated UPnP discovery, and the Bridge Pro does not announce itself over UPnP. In a home with a BSB002 and a Bridge Pro, SSDP finds the BSB002, so mDNS is never run and the Pro is never found.
**Suggestion:** run mDNS first (the method Signify recommends) and SSDP, merge the results by `bridgeid`, and keep N-UPnP as the last resort.
Minor: the comment on `SCAN_CACHE_MS` says the core allows one mediated scan per 10 s. According to the Gladys spec (`network-discovery.md`), that limit only applies to `udp-active-broadcast`. SSDP and mDNS are only limited to one concurrent scan.
### 🟡 4.9 The reported color gets darker as brightness goes down
- `xyToRgb(state.xy, state.bri)` uses the brightness as luminance ([`mapping.js#L158`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/mapping.js#L158)). Brightness is already its own feature, but here it also darkens the color.
- I checked with the same formula:
| Color | bri 254 | bri 64 (25 %) | bri 25 (10 %) |
| Warm white `xy 0.4573, 0.41` | `#ffaf5d` | `#b97d3f` (brown) | `#785026` |
| Red | `#ff0000` | `#ff0000` | `#c60000` |
- Consequences:
- the color picker shows a wrong color;
- every brightness change also publishes a color change;
- a scene that copies the "current color" reapplies a darkened color.
- HA keeps the chromaticity (`xy`) separate from brightness. Its v1 code also clamps colors to the light's gamut (`capabilities.control.colorgamut`); without that clamp, the color Gladys sends and the one the bridge reports back differ, and the picker jumps.
**Suggestion:** compute the color at full luminance (`Y = 1`), and apply the gamut on the command side.
### 🟡 4.10 Effects, scene options, transitions
- **Effects:** HA exposes the v2 effects and the sunrise/sunset timed effects ([`v2/light.py#L134`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/v2/light.py#L134)). Gladys could expose them as `effect-mode` with `supported_options`, filled from each light's `effects.status_values`.
- **Scenes:** the scene action could gain optional fields for *dynamic* (the palette only plays through v2), *brightness* and *transition*, plus smart scenes (v2-only).
- **Gradient lights:** HA now creates one entity per segment ([`v2/light.py#L367`](https://github.com/home-assistant/core/blob/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue/v2/light.py#L367)).
### 🟡 4.11 No recovery path when the certificate changes
- Once a fingerprint is pinned, any other certificate is refused as a "possible impersonation" ([`https.js#L71`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/https.js#L71)), and the bridge stays unusable until it is paired again.
- Signify has already replaced the bridges' self-signed certificates with certificates from its own CA through a firmware update. A certificate renewal would cut the bridge off the same way.
**Suggestion:** accept a new certificate if it chains to the Signify Hue root CA (published on the developer portal) **and** its CN is the bridge id, then pin it again. Pinning stays the fallback for old self-signed certificates.
Also, the comment in [`https.js#L10`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/https.js#L10) says this is "the same trust model Home Assistant uses". That is not accurate: aiohue disables TLS verification entirely (`ssl=False`, [`v2/__init__.py#L223`](https://github.com/home-assistant-libs/aiohue/blob/edfdc8a8e320d0f30628f882c0902b4ab0595d19/aiohue/v2/__init__.py#L223)). The integration is **stricter** than HA here, which is good; it just needs a way to recover.
### 🟢 4.12 Smaller items
- **Capabilities:** they are detected from the `type` string ([`mapping.js#L56`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/mapping.js#L56)).
- An unknown type falls back to on/off only, whereas HA's v1 code falls back to *full* support, and v2 describes capabilities per resource.
- `capabilities.control` (`colorgamuttype`, `ct`) and the keys present in `state` would be more reliable.
- **Temperature bounds:** `ct` bounds equal to `0` are accepted ([`mapping.js#L192`](https://github.com/cicoub13/gladys-philips-hue/blob/5de09d7e012f56cf3978cc5f32c05a611ee73230/src/hue/mapping.js#L192)). HA falls back to 153–500 when a bound is missing or zero. With `0`, the temperature feature becomes unusable.
- **Smart plugs** (`On/Off plug-in unit`) are published in the `light` category. In Gladys, a "turn off the lights" scene action would then cut a plug that may power something else entirely. The `switch` category would be safer. HA exposes plugs as lights too, so this would be an improvement over HA.
- **Device information:** model, manufacturer and firmware are not published (`modelid`, `productname`, `swversion`); they could go in `params`. **Identify** (`alert: select`) is not supported either.
- **Echoed temperature:** the value echoed after a temperature command is the requested one, not the clamped one actually sent.
- **AGENTS.md** says `CHANGELOG.md` "stops at 1.1.1"; it now goes up to 2.0.3.
## 5. Already at or above Home Assistant's level
- **100 % local**, link-button pairing, and the outcome is split per cause (paired / button not pressed / unreachable / not a bridge) with an actionable message.
- **Bridge identification** through `/api/config`: printers and NAS found by a noisy mDNS scan are never offered as bridges.
- **HTTPS fallback at identification:** new pairings work on firmware 1.78, where HA's pairing currently fails.
- **TLS:** certificate CN checked against the bridge id, then the fingerprint is pinned. aiohue does not verify at all.
- **Credential care:** the username never appears in logs (`redact`), `bridges.json` is `0600` and written atomically, and a failed write is reported instead of failing the pairing.
- **Resilience:**
- background resync with backoff and jitter;
- an empty device list is never published, so the Discovery tab is not wiped by a network glitch;
- `commandSeq` stops a stale read from undoing a command;
- IP-based external_ids are preserved through `platformKey`.
- **Hue scenes by name:** forgiving matching, and when it fails the error lists the scenes and rooms that exist.
- **BSB001 support**, like HA's v1 code.
- **Unit tests** cover the pairing, discovery, HTTPS, store and refresh paths.
## 6. Suggested roadmap
**Phase 0: patch release (urgent)**
- Automatic HTTP → HTTPS switch with the same key, and HTTPS first at identification (§1).
- Light availability: transport pill, plus on/off = 0 when `reachable: false` (§4.1).
- "Forget bridge" action (§4.6).
- Color at full luminance (§4.9).
- Fix the IP-change paragraph in the docs (§4.7).
**Phase 1: v2 foundation (as HA, homebridge-hue2 and openHAB do)**
- Detect a v2 bridge like aiohue's `is_v2_bridge`: `GET https://<ip>/clip/v2/resource` answers `403` without a key.
- Use the v2 API on BSB002/BSB003 and keep v1 for BSB001.
- **Keep the external_ids:**
- a v2 light carries `id_v1` (`/lights/<n>`), which maps it back to the v1 `uniqueid` used today;
- this mapping needs a test before any release, because a changed external_id orphans every device users have created.
- Event stream with reconnection, plus polling as a fallback.
- One request queue per bridge (§4.5).
- Discovery: mDNS first and merge by bridge id (§4.8); automatic IP update (§4.7); detection of a migrated bridge (§4.6).
**Phase 2: HA parity**
- Rooms and zones as grouped lights (§4.4).
- Motion, light level, temperature, battery, contact and tamper sensors; buttons and Tap Dial rotation; MotionAware.
- Switches to enable/disable sensors and Hue automations.
- Effects, gradient segments, scene options (dynamic, brightness, transition), smart scenes.
**Phase 3: polish**
- Device information, identify, plugs as `switch`, chain verification against the Signify CA (§4.11).
## 7. Suggested hardware test matrix
- BSB001
- BSB002 on a firmware that still accepts HTTP
- BSB002 on 1.78+
- BSB003
- a BSB002 → BSB003 migration
- two bridges at once
Each one with: an Extended color light, a Color temperature light, a Dimmable light, a smart plug, a third-party bulb (IKEA/Innr), a gradient strip, a motion sensor, a dimmer switch and a Tap Dial.
## References
- Signify: [Hue developer news](https://developers.meethue.com/): "Deprecation of HTTP support" (2025-06-04), "APIs available for MotionAware and migration to Bridge Pro" (2025-09-04), "Multi-bridge migration support is live" (2025-12-15)
- HTTP blocked on BSB002 `1.78.0`: [home-assistant-libs/aiohue issue 708](https://github.com/home-assistant-libs/aiohue/issues/708)
- Bridge Pro is HTTPS-only, no UPnP, MotionAware is v2-only, certificates changed: [ebaauw/homebridge-hue issue 1219](https://github.com/ebaauw/homebridge-hue/issues/1219), [soffes/hue pull request 56](https://github.com/soffes/hue/pull/56)
- Home Assistant: [`homeassistant/components/hue`](https://github.com/home-assistant/core/tree/7deeb959c2a72aaa55d8b7a89b3be321c74c0666/homeassistant/components/hue), [aiohue](https://github.com/home-assistant-libs/aiohue/tree/edfdc8a8e320d0f30628f882c0902b4ab0595d19)
- Gladys: external integration spec (`docs/specs/external-integrations/`: `publishTransports`, `supported_options`, `network_discovery`), `DEVICE_FEATURE_CATEGORIES` in `server/utils/constants.js`
