Hi everyone! ![]()
As promised in the Domadoo post, here’s a look at the Amazon Black Friday Week deals, which started this week.
I reviewed over a hundred products and kept only those that work with Gladys: via Zigbee through the Zigbee2mqtt integration (locally, without cloud or subscription), via Matter, or through native integrations and those from the store.
Prices checked on November 20 on amazon.fr. They change quickly (sometimes within the day): check the product page before ordering.
About discounts: Amazon often displays a large percentage calculated based on the “recommended price,” which no one actually pays. In this post, the discount indicated is calculated based on the lowest price in the last 30 days, when Amazon displays it. It’s less spectacular, but it’s the real deal. Example: the ZBDongle-E key is displayed at “-43 %,” but it’s only -5 % compared to its price last month.
The Zigbee Coordinator: The Basis of Everything
| Product | Price | Discount |
| Sonoff ZBDongle-E The key I recommend, and that I use daily |
€16.99 | -5 % |
| Sonoff ZBDongle-P CC2652P chip, very reliable |
€21.14 | -5 % |
| Sonoff Dongle-PP10 New generation (CC2674P10), supported by Zigbee2MQTT |
€28.90 | -12 % |
The ZBDongle-E at €16.99 is a bit cheaper than at Domadoo right now. Consider a USB 2.0 extension cord to move it away from your server: USB 3.0 ports interfere with 2.4 GHz.
Zigbee Sensors
| Sonoff SNZB-06P24 mmWave radar presence: detects even a stationary person |
€17.66 | -30 % |
| Sonoff SNZB-03PR2 Motion detector + brightness |
€13.32 | -20 % |
| Sonoff SNZB-02UL Temperature + humidity with large e-ink display |
€19.90 | -21 % |
| Sonoff SNZB-02P Temperature + humidity, barely over €10 |
€10.43 | -5 % |
| Sonoff SNZB-02D (pack of 2) Temperature + humidity with LCD display |
€21.28 | -5 % |
| Sonoff SNZB-04P Door/window opening detector |
€9.48 | -5 % |
| Sonoff SNZB-05P Water leak detector |
€10.43 | -5 % |
| Aqara Motion Sensor P1 · 2-pack for €37.59 The motion detector from the “Recommended Equipment” page |
€20.99 | -16 % |
| Aqara FP300 Wireless 5-in-1 presence (radar, PIR, light, temp., humidity), to be used in Zigbee mode |
€42.49 | -15 % |
| ThirdReality tilt sensor Know if the garage door is open |
€11.99 | -40 % |
| ThirdReality vibration sensor End of washing machine cycle, impacts on a door… |
€11.99 | -40 % |
| ThirdReality multifunction night light Night light + motion detector + brightness, and Zigbee router |
€18.99 | -37 % |
| ThirdReality soil moisture sensor Know when to water the plants |
€11.99 | -40 % |
Aqara cards indicate “Requires Aqara Hub”: not with Gladys. They pair directly to your Zigbee key via Zigbee2MQTT.
Zigbee Smoke Detectors
To be coupled with the Gladys alarm to receive a notification on your phone even when you’re not there.
| NOUS E8 Photoelectric detector, 85 dB alarm |
€22.42 | -23 % |
| Heiman HS1SA-E Plus Replaceable 5-year battery |
€26.57 | -16 % |
| Aqara smoke detector The most compact, works without Aqara hub with Zigbee2MQTT |
€35.99 | -20 % |
Heating
With the thermostat management in Gladys.
| Sonoff TRVZB · 2-pack for €40.75 Zigbee thermostatic head, 100 % local |
€21.53 | -5 % |
| Aqara W100 Temperature sensor with screen and buttons, in Zigbee |
€33.99 | -15 % |
| Netatmo thermostatic head · 3-pack for €139.99 Via the Netatmo integration from the store |
45,99 € | -38 % |
| tado° Smart Thermostat X · wired X kit at 129,99 € Via the tado° integration from the store |
64,99 € | -26 % |
Plugs and Modules
| Sonoff S60ZBTPF · pack of 2 at 21,28 € · pack of 4 at 39,99 € Zigbee 16A plug with power measurement, and Zigbee router |
12,78 € | -9 % |
| NOUS A4Z Outdoor weatherproof double plug with power measurement |
23,71 € | -30 % |
| Sonoff MINI-ZB1GSP 16A micro-module with power measurement |
16,02 € | -20 % |
| Sonoff MINI Duo-L 2-channel no neutral micro-module |
18,88 € | -14 % |
| Sonoff ZBMINIL2 No neutral micro-module, ideal for old installations |
11,86 € | -5 % |
| Sonoff ZBMINIR2 Micro-module with neutral, less than 10 € |
9,96 € | -5 % |
| Sonoff MINI-ZBD Dry contact relay: gate, garage door, boiler… |
12,26 € | -18 % |
| Sonoff MINI-ZBRBS (pack of 2) Zigbee roller shutter module |
31,52 € | -5 % |
| Shelly Plus 1PM Wi-Fi 16A module with measurement, via the Shelly integration (local) |
23,99 € | -33 % |
| Shelly Plus 2PM Wi-Fi roller shutter or 2-channel module |
65,99 € | -22 % |
Lighting
Philips Hue bulbs are Zigbee: they pair directly to your Zigbee key, without a Hue bridge. And they strengthen the network mesh.
| Philips Hue Essential A60 E27 (pack of 4) Color, 806 lm, so 11,25 € per bulb |
44,99 € | -36 % |
| Philips Hue Essential GU10 (pack of 4) Colour spots, €11.25 per spot |
€44.99 | -25 % |
| Philips Hue White & Color A60 E27 (set of 4) Premium Hue |
€109.99 | -31 % |
| Philips Hue LED Strip Flux 5 m 2000 lm |
€69.99 | -18 % |
| Philips Hue Tap Dial 4-button remote + dial |
€32.49 | -35 % (vs recommended price) |
| Philips Hue Dimmer Switch The classic |
€18.08 | -18 % (vs recommended price) |
| WiZ colour bulb E27 (set of 2) Wi-Fi, via WiZ integration (local) |
€14.99 | -21 % |
| Nanoleaf Matter LED strip 5 m Matter over Wi-Fi: adds to Gladys without a hub |
€36.49 | -27 % |
Cameras
Gladys displays cameras that offer an RTSP stream, via the Camera integration. For Reolink cameras, there is also a Reolink integration in the store (detection, spotlight, siren, PTZ).
| Tapo C220 2K indoor, 360° motorised |
€24.90 | -31 % |
| Tapo C230 3K indoor, 360° motorised |
€33.24 | -13 % |
| Reolink RLC-510A · dome version RLC-520A PoE 5 MP outdoor, the reliable choice |
€59.49 | -15 % |
| Reolink RLC-811A PoE 4K outdoor, 5x optical zoom |
€103.99 | -20 % |
| Reolink Duo 3 PoE Dual lens, 180° panoramic view |
€139.99 | -29 % |
| Reolink Video Doorbell PoE · Wi-Fi version at €97.49 Video doorbell with chime |
€85.49 | -16 % |
Avoid battery-powered Reolink cameras (Argus range…): they do not offer an RTSP stream.
Multimedia and voice assistants
| Echo Dot (2022) To control Gladys by voice via the Alexa integration |
€39.99 | -56 % |
| Echo Show 8 (new generation) Same thing, with a screen |
€129.99 | -41 % |
| Sonos Era 100 SL Announcements and music from your scenes, via the Sonos integration |
€149.99 | -24 % |
| Sonos Arc Ultra Sonos’ high-end soundbar |
€832.02 | -24 % |
Other compatible ecosystems
Thanks to the store integrations, Gladys also controls many devices from major brands. Some great deals:
| Netatmo Weather Station Via the Netatmo integration |
€99.99 | -21 % |
| Roborock Qrevo S Pro · Saros 10R at €499.99 (-29 %) Robot vacuum mop, via the Roborock integration |
€299.99 | -21 % |
| Ecovacs Deebot T50 Omni Gen3 Via the Ecovacs integration |
€234.99 | -21 % |
| Dreame L10s Pro Gen 3 Via the Dreame integration |
€168.00 | -16 % |
| Somfy TaHoma Switch + consumption sensor For your Somfy shutters (RTS / io), via the Somfy TaHoma integration |
€149.00 | -25 % |
| SwitchBot Hub Mini Matter · curtain push at €67.39 (-25 %) Via the SwitchBot integration |
€49.99 | -16 % |
| BroadLink RM4 Mini Infrared remote (AC, TV…), via the Broadlink integration |
€32.29 | -15 % |
| Withings Body Comp Connected scale, via the Withings integration |
€129.00 | -13 % |
| Nuki Smart Lock Go (2025) Connected lock, see the Nuki integration |
109,00 € | -27 % |
A word about Thread : Gladys is a Matter controller, so Matter devices in Wi-Fi (like the Nanoleaf strip above) are added without buying anything extra. For Matter devices in Thread (Eve, some Aqara, Nuki Go…), a Thread border router is needed on the network. Conveniently, the Aqara Hub M3 is at 119,99 € (-25 %) and the Hub M200 at 59,49 € (-15 %).
Idea: a Zigbee starter kit for less than 100 €
To get started (or equip a loved one for Christmas
- 1x Sonoff ZBDongle-E : 16,99 €
- 2x Sonoff SNZB-02P : 20,86 €
- 1x Sonoff SNZB-03PR2 : 13,32 €
- 1x Sonoff S60ZBTPF (pack of 2) : 21,28 €
- 1x Sonoff SNZB-04P : 9,48 €
- 1x Sonoff SNZB-05P : 10,43 €
Total: 92,36 € for a coordinator, two temperature sensors, a motion detector, two connected plugs, an opening detector, and a water leak detector, all locally with Gladys.
Amazon or Domadoo?
For the products present in both posts, it really depends on the reference:
| Product | Amazon | Domadoo |
| Sonoff ZBDongle-E | 16,99 € | 18,04 € |
| Sonoff SNZB-06P24 | 17,66 € | 23,66 € |
| Sonoff SNZB-03PR2 | 13,32 € | 15,19 € |
| Sonoff SNZB-02UL | 19,90 € | 23,66 € |
| Sonoff MINI-ZB1GSP | 16,02 € | 18,90 € |
| Sonoff S60ZBTPF | 12,78 € | 12,34 € |
| Sonoff ZBMINIL2 | 11,86 € | 10,44 € |
For the rest (LiXee ZLinky, NodOn, SMLIGHT, Owon…), it’s at Domadoo that it happens: these products are unavailable or more expensive on Amazon.
And to run Gladys?
I didn’t find a real deal on the Intel N150 mini-PCs we recommend. To choose, our guide Which mini-PC for home automation? is here. ![]()
And you, what are you craving this year? Tell us in the comments
And if you see a good deal compatible with Gladys, share it here!
Amazon links in this post are affiliate links: if you order through these links, Gladys receives a small commission, with no extra cost for you. As an Amazon Partner, Gladys earns a commission on qualifying purchases. This is one of the ways to support the development of the project. Thank you! ![]()
