[Broadlink] Devices detected but no commands work
Hi,
Since I got back from vacation (about two weeks ago), I’ve been having trouble with the Broadlink integration.
  • Broadlink Integration → Available Broadlink Devices: Both of my devices are correctly detected, RM4 Mini and RM4 Pro.
  • Broadlink Devices → My created remotes are also present.
  • The Broadlink devices are present on my network and respond to ping.
  • However, no commands work in Gladys, whether by directly pressing a command or via a scene.
Has anyone else encountered the same issue with the Broadlink integration?
Thanks!
Hello @b3n.0
I just tested it at my place with my RM4mini and it works well.
I did a learning session on a new device, not a test from an already registered old device.
Hey @mutmut
Yes, if I create a new device it works, I just replaced the « power » button of my video projector… test ok, replacement in the scenes ok…
Now just the laziness of doing the same thing with all the others :weary_face:
Continuation of the story…
I just discovered that the « linked peripheral » in the device configuration had disappeared
I put it back, validated the configuration and it’s back up and running! :partying_face:
However, I don’t know why they disappeared!
I think we’ll need to 1/do an external integration and 2/put this test check in it.
