I am having an error with Zigbee2MQTT.
docker logs gladys-z2m-zigbee2mqtt
Using '/app/data' as data directory
Zigbee2MQTT:info 2021-08-11 10:14:29: Logging to console and directory: '/app/data/log/2021-08-11.10-14-27' filename: log.txt
Zigbee2MQTT:info 2021-08-11 10:14:29: Starting Zigbee2MQTT version 1.19.1 (commit #9bd4693)
Zigbee2MQTT:info 2021-08-11 10:14:29: Starting zigbee-herdsman (0.13.111)
Zigbee2MQTT:info 2021-08-11 10:14:32: zigbee-herdsman started
Zigbee2MQTT:info 2021-08-11 10:14:32: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210120,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 2021-08-11 10:14:32: Currently 9 devices are joined:
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d0003d43a15 (0x00158d0003d43a15): WXKG01LM - Xiaomi MiJia wireless switch (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d0002a65e93 (0x00158d0002a65e93): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d00044f23e9 (0x00158d00044f23e9): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d0002a6e6e6 (0x00158d0002a6e6e6): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d00044f24a8 (0x00158d00044f24a8): MCCGQ01LM - Xiaomi MiJia door & window contact sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d000247747b (0x00158d000247747b): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d00024773c2 (0x00158d00024773c2): RTCGQ01LM - Xiaomi MiJia human body movement sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d0006d5736c (0x00158d0006d5736c): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: 0x00158d0006e4902e (0x00158d0006e4902e): WSDCGQ11LM - Xiaomi Aqara temperature, humidity and pressure sensor (EndDevice)
Zigbee2MQTT:info 2021-08-11 10:14:32: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2021-08-11 10:14:32: Started frontend on port 0.0.0.0:8080
events.js:353
throw er; // Unhandled 'error' event
Error: listen EADDRINUSE: address already in use 0.0.0.0:8080
at Server.setupListenHandle [as _listen2] (net.js:1318:16)
at listenInCluster (net.js:1366:12)
at doListen (net.js:1503:7)
at processTicksAndRejections (internal/process/task_queues.js:83:21)
Emitted 'error' event on Server instance at:
at emitErrorNT (net.js:1345:8)
at processTicksAndRejections (internal/process/task_queues.js:82:21) {
code: 'EADDRINUSE',
errno: -98,
syscall: 'listen',
address: '0.0.0.0',
port: 8080
It seems to be blocking related elements, I no longer receive new values.
My key is a zzh!.
Any ideas?
Thanks ![]()
