Integration Creator: launch an external integration in one click
Hello everyone :wave:
Since the arrival of external integrations, many of us want to get started. You then need to check that no one is already working on it, create the repository from the template, set up GitHub, announce the integration on the forum… It’s repetitive, and it’s easy to forget a step.
I’m preparing a small tool to automate all of this: Integration Creator.
:mag: 1. Find a free integration
It relies on the tracker by @William-De71 (thanks to him :pray:):
You can immediately see what exists, what is in progress, and what is free.
:rocket: 2. Start development with one click
  • Create the repository from the official template integration-template-js, with a name in gladys-
  • Customization: manifest, README, CHANGELOG
  • Documentation in 4 languages: French and English (required for the store), German and Spanish
  • GitHub settings: “squash” merge, security, Dependabot, automatic Watch
  • Topic gladys-integration-wip: the integration appears “in progress” in the tracker, without arriving empty in the store
  • Follow-up issue with the specifications
  • Announcement on the forum to avoid duplicates
:robot: 3. Develop with Claude (optional)
  • Claude can write the code from the specifications and propose a pull request.
  • It uses your Claude subscription (Pro or Max), no paid API key.
  • You can follow its progress in real-time and write to it from the app.
  • Without Claude, everything else works the same.
:package: 4. Publish
A button launches the release, then adds the topic `glad
