Voilà ce que j’entends par complications :
pi@gladys:~ $ /home/pi/gladys/node_modules/gladys/rpi-update.sh
[PM2] Applying action stopProcessId on app [gladys](ids: 0)
[PM2] gladys ✓
npm WARN peerDependencies The peer dependency mocha@>=1.20.0 included from grunt-mocha-test will no
npm WARN peerDependencies longer be automatically installed to fulfill the peerDependency
npm WARN peerDependencies in npm 3+. Your application will need to depend on it explicitly.
npm WARN deprecated minimatch@2.0.10: Please update to minimatch 3.0.2 or higher [[B\void a RegExp DoS issue \
sails@0.12.13 preinstall /home/pi/gladys/node_modules/gladys/node_modules/sails
node ./lib/preinstall_npmcheck.js
Sails.js Installation: Checking npm-version successful
bcrypt@1.0.2 install /home/pi/gladys/node_modules/gladys/node_modules/bcrypt
node-pre-gyp install --fallback-to-build
node-pre-gyp ERR! Tried to download(undefined): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.2/bcrypt_lib-v1.0.2-node-v46-linux-arm.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.2 and node@4.5.0 (node-v46 ABI) (falling back to source compile with node-gyp)
make: Entering directory ‘/home/pi/gladys/node_modules/gladys/node_modules/bcrypt/build’
CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
C’est ce que j’obtiens après avoir lancé la mise à jour.
