Gladys Assistant 4.45: DuckDB, a revolution in Gladys! ⚡
FYI, I released last night Gladys Assistant 4.45.1, on the agenda:
  • Fixed the EDF Tempo widget to migrate to the RTE API instead of the EDF API which no longer worked
  • Added a nightly task at 23:00 that will purge DB messages older than 15 days. As soon as you’re up to date and a night has passed, I recommend doing a cleanup of the SQLite DB to really free up space ^^ Now that your sensor states are no longer in SQLite, it should be quick!
  • The API no longer allows a user to update their own role
  • CalDAV: Fixed a bug on recurring events (thanks @bertrandda !)
