How do you configure TLS for the gladys portal? is there a native way to do it or do i have to configure a reverse proxy?
Hello. The native way is Gladys Plus via the subscription Gladys Plus : accès distant sécurisé pour ta domotique | Gladys Assistant
Otherwise, you can install a reverse proxy, manage the certificate, security, etc.
ah, ok. thank you.
If you need help with the reverse proxy solution, of course we can guide you.
