Feature description
KNX support could be a plus.
There are several ways to communicate with KNX.
via KNXNet/IP: in multicast or in tunneling
via TPUART; with a USB or serial device.
For KNXNet/IP, there is already a node.js library:
https://www.npmjs.com/package/knx
The most complex part, in my opinion, is that there is no automatic discovery of devices. Therefore, it would be necessary to either import an ETS project or be able to create devices manually in Gladys.
As a developer myself, I would like to participate in the development and lend a hand, but I don’t really know where to start or how…
I am a new user here. Overall, I really like the idea behind this project. However, I notice that KNX and Modbus are essential components that seem to be missing at the moment.
I wonder if other members feel the same. In addition, I am open to the possibility of contributing to the development of these features if the community is interested.
Your thoughts and ideas are welcome.
Thank you
Hi @moustic!
KNX is in the catalog: the external integration KNX (William-De71, v0.2.0). You need Gladys 5.3 or newer.
It speaks KNXnet/IP. You expose lights, shutters, sensors, and thermostats. KNX doesn’t discover itself: you specify the group addresses to report. TPUART (USB or serial) is not the way of this integration, which targets the IP network.
I’m moving this topic to « Delivered Requests ». If there’s still a case that doesn’t fit, open a new topic: it will be easier to follow.
