External integrations: update to Gladys 5.3, JS SDK 0.16 and the store
Hello everyone!
A lot has changed in recent weeks regarding external integrations: new version of the JavaScript SDK (@gladysassistant/integration-sdk v0.16.0), new fields in the manifest, new validation rules in the store… This post gathers everything you need to do to update your integration, and what you can do additionally if you wish.
Good news: there is no mandatory breaking change. An integration published today remains indexed. But a few points deserve a check, and the new features are worth a look :slightly_smiling_face:
:white_check_mark: The Quick Checklist
  • Upgrade the SDK to ^0.16.0 (Node.js ≥ 20)
  • Check your poll_frequency: in milliseconds, and only among the allowed values
  • Use publishChangedStates if you publish many states (limit of 300 states/minute)
  • Add categories (and optionally keywords / countries) to the manifest
  • Check that gladys_version covers all the fields you declare
  • Have docs/en.md and docs/fr.md (300 characters minimum each)
  • Check the cover: JPEG or PNG, 800×534 px exactly, 150 Ko maximum
  • Run the local validator: npx github:GladysAssistant/integration-store
  • Publish: increment version + docker_image, pushing the image before the manifest
The details of each point are below.
1. Updating the SDK
npm install @gladysassistant/integration-sdk@^0.16.0
The SDK requires Node.js ≥ 20. Make sure to check the base image of your Dockerfile.
What has changed since v0.11:
Version Main New Features
0.12 Sync with Gladys 4.86: electric/gas network sensors, PTZ cameras, wakeOnLan(), account_link config field
0.13 Six new weather phenomena in the pivot format, sirens, battery recharge, scan result format
0.14 Scene triggers and actions, dashboard widgets, getHouses(), network carbon and smoke sensors
0.15 DEVICE_POLL_FREQUENCIES, Fake Gladys for your tests, parseMdnsTxt(), publishChangedStates(), calendar type, energy contracts, forms in widget buttons, house selector, publishEnergyConsumption()
0.16 Music players, ai and tts types, should_poll becomes optional
The full changelog is on GitHub.
2. Points to Check in Your Code
:stopwatch: poll_frequency: in milliseconds, and only certain values
This is the most common pitfall. poll_frequency is expressed in milliseconds, and only these values are accepted: 1 s, 2 s, 10 s, 15 s, 30 s or 1 min. Any other value (300 thought in seconds, 300000 for 5 minutes…) makes publishDiscoveredDevices fail with a 400 error.
Use the constants exported by the SDK:
import { DEVICE_POLL_FREQUENCIES } from '@gladysassistant/integration-sdk';
await gladys.publishDiscoveredDevices([
    name: 'Weather Station',
    external_id: ids.device,
    should_poll: true,
    poll_frequency: DEVICE_POLL_FREQUENCIES.EVERY_MINUTES, // 60000 ms
    features: [/* … */],
A few clarifications:
  • One minute is the slowest pace. To go slower (cloud API with quota, user setting in minutes), keep EVERY_MINUTES and ignore unnecessary polls in onPoll, or use your own timer.
  • Since Gladys 5.3, poll_frequency is enough: the core activates should_poll on its own. If your gladys_version accepts older versions, keep should_poll: true. If you set should_poll, it must be a boolean.
  • These two fields are read when the device is created: modifying them later does not update an already created device.
:chart_decreasing: 300 states per minute limit: publishChangedStates
The host API limits POST /state to 300 states per minute and per integration. If you query many devices, only publish what has changed:
// replaces publishStates: only modified values go to Gladys
await gladys.publishChangedStates(states);
// and we still return an unchanged value every 30 minutes
await gladys.publishChangedStates(states, { heartbeat: 30 * 60 * 1000 });
The SDK splits batches of more than 100 states, returns what Gladys refused, and forgets the values of a device when the user creates, modifies, or deletes it.
:label: Use constants, not hardcoded strings
DEVICE_FEATURE_CATEGORIES, DEVICE_FEATURE_TYPES and DEVICE_FEATURE_UNITS are a copy of server/utils/constants.js in Gladys, and they are kept up to date with each version. If you manually copied strings, now is the time to switch to constants: you avoid typos and have autocompletion.
:sun_behind_rain_cloud: Weather integrations: night is deprecated
The night condition is still accepted but it is deprecated. A rainy night is written weather: 'rain', is_day: false. Also think about the new conditions of the pivot format and the type field of alerts (WEATHER_ALERT_TYPES).
:clapper_board: Scene triggers and actions: keys are final
If you declare scene_triggers / scene_actions, a published key must never be renamed. And adding a required field without default to an existing action breaks the scenes that use it.
3. Updating the Manifest
The golden rule: gladys_version must cover what you declare
Old versions of Gladys reject fields they don’t know. The store therefore checks that the minimum of your gladys_version covers each declared field, otherwise the integration is rejected. This way, the user simply sees « requires Gladys ≥ X » in the catalog, instead of an installation that fails without explanation.
You declare… Minimum gladys_version
categories >=4.86.0
type: "provider", widgets, scene_triggers, scene_actions >=5.1.0
type: "calendar", account_schema, energy_contracts, a field with source: "houses" >=5.2.0
type: "ai", type: "tts", music, keywords, countries >=5.3.0
:warning: Conversely, do not increase gladys_version without reason: your integration would be hidden from users who have not yet updated Gladys.
:card_index_dividers: categories: your place in the catalog
Between 1 and 3 categories among: climate, lighting, energy, security, multimedia, appliances, environment, protocols, network, notifications, assistants, services, transport, vehicles, servers, leisure.
The last four (transport, vehicles, servers, leisure) have just been added. Without categories, your integration remains visible in « All » and in the search, but does not appear in any section. For already published integrations, the store applies in the meantime a fallback mapping (data/category-fallback.json). Declaring your own categories is the best way to be well placed. An unknown category is simply ignored, with a warning.
:magnifying_glass_tilted_right: keywords and countries (Gladys ≥ 5.3)
  "gladys_version": ">=5.3.0",
  "categories": ["energy"],
  "keywords": ["linky", "enedis", "téléinfo"],
  "countries": ["FR"]
  • keywords : 1 to 10 terms of 2 to 30 characters, never displayed, used only by search (brands, models, synonyms, cities or networks served…).
  • countries : 1 to 20 ISO country codes in uppercase. Do not include this if your integration works everywhere (this is the default behavior). If you declare it, instances located in another country will no longer see the integration in the catalog sections (it remains findable via search). Think about this for a regional integration: national weather service, transport network, energy provider, ISP…
Do not forget: declaring keywords or countries requires gladys_version ≥ 5.3.0.
4. Documentation and cover
  • Mandatory documentation : docs/en.md and docs/fr.md at the root of the repository, 300 characters minimum each, following the sections of the template (Presentation / Prerequisites / Configuration / Troubleshooting). If one is missing, the integration is rejected. The files are hosted by the store and displayed in the installation and configuration screens of Gladys.
  • New : docs/de.md and docs/es.md are optional. If they are present (300 characters minimum), they are displayed to German and Spanish users.
  • Cover : JPEG or PNG, exactly 800×534 px, 150 Ko maximum, direct https URL (without redirection). The simplest: a raw.githubusercontent.com URL to a file in your repository. An invalid cover does not block indexing, but you will have a default image in the catalog.
5. Validate locally before publishing
No need to wait for hourly indexing to discover a rejection! At the root of your repository:
The validator performs exactly the same checks as the store robot (schema, gladys_version rules, categories, documentation, existence of Docker images, cover) and displays all problems at once. Exit code 0 = the integration would be indexed, 1 = it would be rejected.
In the CI of your pull requests
In a PR that increments the version, the Docker image is generally not yet published: add --skip-image-check to skip only this check.
- uses: actions/setup-node@v4
  with:
    node-version: 24
- run: npx github:GladysAssistant/integration-store --skip-image-check
Run it without the option once the images are published, for example in the last step of your release workflow.
6. Publish the new version
  1. Increment version (strict semver) and docker_image (with an explicit tag) in the manifest.
  2. Publish the Docker image before the manifest that references it arrives on the default branch: the store checks that the image exists and is downloadable without authentication. If the image is missing, the integration is removed from the catalog until the next indexing.
  3. Push. At the next indexing (every hour), Gladys will display “update available” to your users.
Your integration does not appear? Look at the public rejected.json file of the store: each rejection is listed there with its reason (error = not indexed, warning = indexed with a degradation, for example the default cover).
7. Test your integration with the fake Gladys
The SDK now provides an in-memory Gladys for your unit tests: it’s a real GladysIntegration, connected to a fake Gladys instead of the network.
import { test } from 'node:test';
import assert from 'node:assert/strict';
import { createFakeGladys } from '@gladysassistant/integration-sdk/testing';
import { registerHandlers } from '../src/app.js';
test('publishes the temperature on poll', async () => {
  const gladys = createFakeGladys({ config: { api_key: 'key' } });
  registerHandlers(gladys);
  await gladys.connect();
  const [device] = gladys.fake.discoveredDevices;
  assert.deepEqual(await gladys.fake.poll(device), { success: true });
  assert.equal(gladys.fake.lastState(`${device.external_id}:temperature`), 21.5);
It applies the same checks as the host API (prefix of external_id, known categories/types/units, poll_frequency…) and responds with the same 400 errors. You therefore see the errors in your tests rather than with your users.
8. To go further (optional)
If you want to enrich your integration, here is everything that is now possible:
Feature Manifest SDK Gladys
Dashboard widgets widgets onWidgetGet, onWidgetAction, requestWidgetRefresh ≥ 5.1
Scene triggers / actions scene_triggers, scene_actions publishSceneEvent, onSceneAction ≥ 5.1
“Capabilities only” integration type: "provider" — ≥ 5.1
Calendar provider type: "calendar", account_schema publishCalendars, publishCalendarEvents… ≥ 5.2
Energy contracts and calendars energy_contracts publishEnergyCalendar, onEnergyPrice… ≥ 5.2
Dated consumption (readings received later) — publishEnergyConsumption ≥ 5.2
House selection in a form source: "houses" — ≥ 5.2
AI provider (compatible with OpenAI) type: "ai" onAiChat ≥ 5.3
Text-to-speech type: "tts" onTtsSynthesize ≥ 5.3
Music players (navigation, search, queue) music publishNowPlaying, onMusicBrowse, onMusicPlay… ≥ 5.3
Wake-on-LAN network_wake: true wakeOnLan ≥ 4.86
Connection to an account without redirection (QR code…) account_link field onOAuthAuthorizeUrl ≥ 4.86
Everything is documented in the SDK README, and all the manifest rules are in the store README.
If you are stuck on a migration or if a validation rule seems strange to you, reply in this topic or open an issue on integration-sdk-js / integration-store.
Thanks to everyone who develops integrations, the catalog is growing very quickly! :folded_hands:
I see in Gladys’ external integrations that some countries are not mentioned and we see a lot of integrations “external” to France (if I take my case as a French speaker).
In the manifest, we should find the “countries”, no problem. For those who have put it, it works.
There is also in the GladysAssistant/integration-store repo a file that manages the country language: data/country-fallback.json
If I have to make PRs for some integrations that don’t have the country, what would be the best rule: make a global PR on country-fallback.json or a PR per integration?
For now, I’ve made a PR for an integration, but I want to be sure about the next steps.
Hello @mutmut, thanks for taking care of this :folded_hands:
The best approach is for each integration to declare its own countries in its manifest: the author knows best where their integration works. The data/country-fallback.json file is just a temporary solution, filled once in the October catalog to avoid waiting for everyone, and it is meant to disappear. So yes, a PR per integration, as you started doing :+1:
A few rules to ensure these PRs go smoothly:
  1. countries enforces gladys_version >= 5.3.0 in the same PR. Without this, the store rejects the integration, and it disappears from the catalog at the next indexing. Run the validator before proposing the PR: npx github:GladysAssistant/integration-store
  2. Include all countries where the integration is useful, not just France, as a forgotten country hides the integration from its users. For example, Pathé is also in Belgium, Switzerland, and the Netherlands.
  3. Only add countries to truly regional integrations: national weather, transportation, energy or water providers, ISPs, open data… A hardware brand sold worldwide should not have this.
  4. Start with integrations missing from the fallback, i.e., those published since late October. These are the ones currently displayed everywhere. Those already in the file are already correctly filtered, so the PR is still welcome but not urgent.
  5. In the description, include a link to this topic and explain the consequence for the author (Gladys 5.3 minimum), so they can decide knowingly.
Thanks for your feedback!
I’ve already opened the PRs with Claude on about a hundred integrations he found without countries and your points are well listed in them.
I already have @lmilcent and @guim31 who have merged the PRs, I’m waiting for the others to make a final PR on the fallback so that it is (almost) clean.
