Probleme drive Zwave js ui
bonsoir,
j ai un problème depuis cette aprèm, voivi les logs zwave
j ai reinstaller le conteneur mais rien na changer
2024-11-12T18:37:15.172Z DRIVER   ███████╗        ██╗    ██╗  █████╗  ██╗   ██╗ ███████╗          ██╗ ███████╗
2024-11-12T18:37:15.176Z DRIVER   version 14.3.1
2024-11-12T18:37:15.178Z DRIVER
2024-11-12T18:37:15.180Z DRIVER   starting driver...
2024-11-12T18:37:15.181Z DRIVER   opening serial port /dev/zwave
2024-11-12T18:37:15.210Z DRIVER   serial port opened
2024-11-12T18:37:15.216Z SERIAL » 0x15        (1 bytes)
2024-11-12T18:37:16.225Z DRIVER   loading configuration...
2024-11-12T18:37:16.259Z CONFIG   Using external configuration dir /usr/src/app/store/.config-db
2024-11-12T18:37:16.262Z CONFIG   version 14.3.1
2024-11-12T18:37:18.130Z DRIVER   beginning interview...
2024-11-12T18:37:18.133Z DRIVER   added request handler for AddNodeToNetwork (0x4a)...
                                  1 registered
2024-11-12T18:37:18.135Z DRIVER   added request handler for RemoveNodeFromNetwork (0x4b)...
                                  1 registered
2024-11-12T18:37:18.136Z DRIVER   added request handler for ReplaceFailedNode (0x63)...
                                  1 registered
2024-11-12T18:37:18.138Z DRIVER   added request handler for SetLearnMode (0x50)...
                                  1 registered
2024-11-12T18:37:18.140Z CNTRLR   querying Serial API capabilities...
2024-11-12T18:37:18.161Z SERIAL » 0x01030007fb                                                         (5 bytes)
2024-11-12T18:37:18.164Z DRIVER » [REQ] [GetSerialApiCapabilities]
2024-11-12T18:37:19.179Z CNTRLR   Failed to execute controller command after 1/3 attempts. Scheduling next try i
                                  n 100 ms.
2024-11-12T18:37:19.284Z DRIVER » [REQ] [GetSerialApiCapabilities]
2024-11-12T18:37:19.288Z SERIAL » 0x01030007fb                                                         (5 bytes)
2024-11-12T18:37:20.300Z CNTRLR   Failed to execute controller command after 2/3 attempts. Scheduling next try i
                                  n 1100 ms.
2024-11-12T18:37:21.405Z DRIVER » [REQ] [GetSerialApiCapabilities]
2024-11-12T18:37:21.408Z SERIAL » 0x01030007fb                                                         (5 bytes)
2024-11-12T18:37:22.421Z DRIVER   Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
                                  from the controller (ZW0200)
                                      at Driver.sendMessage (/usr/src/app/node_modules/zwave-js/src/lib/driver/D
                                  river.ts:6071:23)
                                      at ZWaveController2.queryCapabilities (/usr/src/app/node_modules/zwave-js/
                                  src/lib/controller/Controller.ts:1144:37)
                                      at Driver.initializeControllerAndNodes (/usr/src/app/node_modules/zwave-js
                                  /src/lib/driver/Driver.ts:1677:46)
                                      at Immediate.<anonymous> (/usr/src/app/node_modules/zwave-js/src/lib/drive
                                  r/Driver.ts:1478:16)
2024-11-12T18:37:22.426Z DRIVER   destroying driver instance...
2024-11-12T18:37:22.432Z DRIVER   driver instance destroyed
je precise que c’est depuis la mise a jour de zwave
il semble que je ne suis pas le seul 9.27.0 Docker won't start on Aeotec Z-Stick Gen5+ · Issue #3997 · zwave-js/zwave-js-ui · GitHub
problème résolut avec la nouvelle mise a jour
