Ultra-intensive week on Gladys
Just a reminder, the week isn’t over, it’s just beginning!!
Still today, tomorrow, and Monday full-time on Gladys :fire::fire:
Hi @pierre-gilles!
« The week has only just begun »: it’s nice to read :fire:
I’m taking this opportunity to bring up an issue we just encountered while developing the Shelly external integration, because we think it affects the SDK/core.
The Problem
publishDiscoveredDevices() (i.e., POST /discovered_device) gets a PayloadTooLargeError: request entity too large as soon as we exceed a little over a dozen devices.
The issue is that the entire discovery is then lost: the devices were found, but nothing appears on the screen, and the user concludes that the integration doesn’t see them.
The Numbers
A Shelly Pro 3EM exposes 24 features (3 phases × active/reactive power, voltage, current, totals, and 8 energy meters). This results in approximately 8.4 KB per device once serialized.
Devices Features Body Size
10 240 82 KB
12 288 99 KB
13 312 107 KB → rejected
17 408 140 KB → rejected
The threshold is therefore around 12 devices, which is quickly reached in an energy monitoring installation. At my place: 19 Shelly devices, including about ten Pro 3EM.
This isn’t just about Shelly — any integration with feature-rich devices (Zigbee, Z-Wave, meters) will hit the same wall.
Why I Can’t Properly Work Around It
The SDK documentation is clear:
publishDiscoveredDevices(devices) — Publishes the complete list of discovered devices (replaces the previous one).
So I can’t split it into multiple sends: the second batch would erase the first, and the user would see fewer devices than before. For now, I’ve implemented a fallback that publishes the largest acceptable subset and logs what was excluded — this prevents silent failure, but it’s still a band-aid.
Also note: publishStates and publishTransports each document a maximum of 100 items per request. publishDiscoveredDevices doesn’t announce any limit, hence the surprise.
Two Proposals
Option A — the bare minimum
Increase the body size limit on this route (e.g., 1 MB). One line on the core side, and it’s immediately resolved, but it remains unbounded.
Option B — consistent with the rest of the SDK (my preference)
Align this route with the publishStates model: a documented limit per request, and the SDK splits it automatically, transparently for the integrator.
On the core side, it would just need a flag:
POST /discovered_device { devices: [...], replace: true|false }
  • replace: true → current behavior (replaces the list)
  • replace: false → merges by external_id
On the SDK side, no API change: publishDiscoveredDevices(devices) sends the first batch with replace: true and the following ones with replace: false. Existing integrations don’t change a line, and those with many devices finally work.
We Can Do It
We have our forks of the core and SDK — if Option B suits you (or Option A if you prefer to keep it simple for now), let us know, and we’ll prepare the PR. You can keep your intensive week for the rest :slightly_smiling_face:
Thanks!
Oh shoot that’s critical!! I’m asking Claude to fix it
Indeed, I can get between 11 and 13 devices max out of the 19 ^^ It works, but there are 5 that never show up (apparently the slowest to respond - very low RSSI, it matches ^^)
The fix is live on master
I had forgotten, in relation to the core PRs Semaine ultra intensive sur Gladys - #21 par Terdious, there will also be those of the SDK:
@Terdious about PRs on the JS SDK, I don’t know if it’s necessary, honestly I think I’ll just tell the SDK « sync with Gladys » every time there’s a change, right?
That would be perfect ^^
I’m closing!!
