Ah, you’ll still need authentication ![]()
On your mini-PC, open the file /var/lib/gladysassistant/zigbee2mqtt/z2m/configuration.yaml, by running:
cat /var/lib/gladysassistant/zigbee2mqtt/z2m/configuration.yaml
You should see at the top of the file:
mqtt:
base_topic: zigbee2mqtt
server: mqtt://localhost:1884
user: gladys
password: TON_MOT_DE_PASSE
Use the username and password ![]()
