Compatibility of Gladys with Thombox?
Hello everyone, I’m new here and I have a problem.
I have a Thombox that uses ARW gateways:
avidsen-protocols
The issue is that to configure my home automation, I was using Zipato, which has simply closed its servers…
I am looking for a solution to regain access to my home automation system without having to replace everything, but I don’t know much about it.
I understood that Gladys is a gateway that could enable this communication, but I don’t think it’s compatible with the Thombox.
Can anyone help me?
Thanks in advance :folded_hands:
Hello @Labourse974 and welcome to Gladys!
Unfortunately, Gladys is not compatible with Thombox.
Hello @pierre-gilles,
Thank you for your response. Do you have a solution?
Best regards
You should check if your Thombox has an API that you can control via Gladys.
Otherwise, look into Node-RED, there might be a plugin!
