I own a Storcube S1000 solar battery (with balcony panels) and I use Gladys Assistant [Gladys version]. I haven’t found a Storcube integration in the integrations catalog. Does it already exist, or is someone working on it?
What I would like to be able to do from Gladys:
See the battery charge level (%)
See the power received from the panels and the power injected into the house
Activate or stop the injection to the home
Schedule daily injection (for example, return energy in the evening)
Use this information in my scenes
The battery works via the Storcube cloud, with an account created in the Storcube mobile application. It does not have local access, to my knowledge.
I am not a developer, but I am willing to test a version as soon as there is one and to provide feedback (my battery is in service at my home).
If anyone knows how to do it, or if another solution exists to connect this battery to Gladys, I am interested.
I’ve looked into what can be done with the StorCube S1000.
No official API, but there is a solution. StorCube does not publish an API, but the mobile app goes through a cloud server (Baterway). Home Assistant users have studied its exchanges, and an integration already exists on their side. I can build on this work (under a free license) to create a Gladys integration.
What would be possible:
the battery charge level (%);
the power received from the panels (the two solar inputs);
the power injected into the home;
activate or cut off the injection: you set the output power between 0 and 800 W, and 0 W means cutting off;
the discharge threshold (the level below which the battery does not go down);
the firmware version and connection status.
For evening injection, no dedicated function is needed: a Gladys scene that sets the output power at a specific time (for example 800 W at 7 p.m., then 0 W at 11 p.m.) will do the job. All values can also trigger scenes, for example « if the battery drops below 20 % ».
The limits to be aware of:
Everything goes through the StorCube cloud: without Internet, or if their server goes down, Gladys no longer receives anything. There is no known local access to the battery.
The API is not official, so StorCube can change it from one day to the next and break the integration.
The StorCube server does not encrypt exchanges (simple HTTP). Your username and password therefore circulate in plain text, just like with the app itself. I advise you to use a password that you do not use anywhere else.
The account does not handle multiple simultaneous connections well. We will have to see if the mobile app and Gladys can coexist.
If you have multiple stacked batteries, only the main battery gives the solar, output, and threshold. The others only give their level and temperature.
What I will need from you:
Confirm that you log in to the app with your email address and a password.
The serial number of your battery (on the label or in the app). No need to post it here, it will only be used for configuration.
The firmware version displayed in the app.
Tell me if you have a single battery or multiple stacked ones.
I don’t have this equipment, so your tests will be essential. I’ll keep you updated as soon as a first version is ready to try.
