Automatically disable Zigbee Network Discovery
When you press the button, it stays active the whole time.
However, in the Zigbee2MQTT interface, this only starts the search for 4 minutes and 15 seconds.
Would it be possible to return the button to its initial position after the same amount of time?
Indeed, we think the network discovery is still active when it is no longer the case.
Hi, a major overhaul of the Zigbee2Mqtt integration is underway and it’s in there :wink:
