Para información, he iniciado el desarrollo de la integración externa para el servicio meteorológico National Weather Service
Una imagen de prueba está disponible
Instalación de la imagen de prueba desde el modo desarrollador:
la imagen docker:
ghcr.io/william-de71/gladys-national-weather-service:dev
el manifiesto:
"manifest_version": 1,
"type": "weather",
"name": "National Weather Service",
"description": {
"en": "Official US forecasts and alerts from the National Weather Service.",
"fr": "Prévisions et alertes officielles du National Weather Service (États-Unis)."
"version": "0.1.0",
"docker_image": "ghcr.io/william-de71/gladys-national-weather-service:dev",
"gladys_version": ">=5.1.1",
"categories": [
"environment"
"cover_image": "https://raw.githubusercontent.com/William-De71/gladys-national-weather-service/main/cover.jpg",
"transports": [
"cloud"
"location": true,
"config_schema": [
"key": "intro",
"type": "section",
"label": {
"en": "Ready to use",
"fr": "Prêt à l'emploi"
"description": {
"en": "Forecasts and alerts work with no configuration: the National Weather Service API is free and needs no key. It covers the United States and its territories only — a house elsewhere gets its weather from another provider.",
"fr": "Les prévisions et les alertes fonctionnent sans configuration : l'API du National Weather Service est gratuite et sans clé. Elle ne couvre que les États-Unis et leurs territoires — une maison située ailleurs reçoit sa météo d'un autre fournisseur."
"links": [
"url": "https://www.weather.gov/documentation/services-web-api",
"label": {
"en": "NWS API documentation",
"fr": "Documentation de l'API NWS"
"key": "contact",
"type": "string",
"label": {
"en": "Contact email (optional)",
"fr": "Email de contact (optionnel)"
"description": {
"en": "Added to the identification the NWS requires from every application, so it can reach you before blocking traffic it finds abusive. Never shared with anyone else.",
"fr": "Ajouté à l'identification que le NWS exige de chaque application, pour qu'il puisse vous prévenir avant de bloquer un trafic qu'il jugerait abusif. Jamais transmis à personne d'autre."
"required": false,
"placeholder": {
"en": "me@example.com",
"fr": "moi@exemple.fr"
"key": "cache_duration",
"type": "number",
"label": {
"en": "Cache duration (s)",
"fr": "Durée du cache (s)"
"description": {
"en": "In seconds, between 0 and 3600. How long a forecast is reused before calling the NWS again. The NWS refreshes its forecasts about once an hour: the default of 600 (10 min) costs no freshness. Set to 0 to always call the API. Alerts are not affected: they are checked on their own schedule.",
"fr": "En secondes, entre 0 et 3600. Durée pendant laquelle une prévision est réutilisée avant de rappeler le NWS. Le NWS met à jour ses prévisions environ une fois par heure : la valeur par défaut de 600 (10 min) ne fait rien perdre en fraîcheur. Mettre 0 pour toujours appeler l'API. Les alertes ne sont pas concernées : elles sont vérifiées selon leur propre rythme."
"required": false,
"default": 600,
"min": 0,
"max": 3600
"key": "alert_check_interval",
"type": "number",
"label": {
"en": "Alert check interval (s)",
"fr": "Intervalle de vérification des alertes (s)"
"description": {
"en": "In seconds, between 30 and 900. How often the official alerts of your houses are checked, for the scene triggers and the alerts widget. A Tornado Warning lasts about 30 minutes: the default of 60 s fires your scenes within a minute of its issuance.",
"fr": "En secondes, entre 30 et 900. Fréquence de vérification des alertes officielles de vos maisons, pour les déclencheurs de scène et le widget des alertes. Une alerte tornade dure environ 30 minutes : la valeur par défaut de 60 s déclenche vos scènes moins d'une minute après son émission."
"required": false,
"default": 60,
"min": 30,
"max": 900
"scene_triggers": [
"key": "alert_issued",
"label": {
"en": "NWS alert issued",
"fr": "Alerte NWS émise"
"description": {
"en": "A new watch, warning or advisory covers the house. Its updates do not fire again. Checked every minute by default.",
"fr": "Une nouvelle veille, alerte ou un avis du NWS couvre la maison. Ses mises à jour ne redéclenchent pas. Vérifié chaque minute par défaut."
"fields": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"fr": "Maison"
"description": {
"en": "Name of the house, exactly as shown in Gladys. Leave empty for every house.",
"fr": "Nom de la maison, exactement comme dans Gladys. Laissez vide pour toutes les maisons."
"required": false
"key": "category",
"type": "multi_select",
"label": {
"en": "Kind of alert",
"fr": "Type d'alerte"
"description": {
"en": "Leave empty for every kind.",
"fr": "Laissez vide pour tous les types."
"required": false,
"options": [
"value": "tornado",
"label": {
"en": "Tornado",
"fr": "Tornade"
"value": "hurricane",
"label": {
"en": "Hurricane / tropical storm",
"fr": "Ouragan / tempête tropicale"
"value": "thunderstorm",
"label": {
"en": "Severe thunderstorm",
"fr": "Orage violent"
"value": "flood",
"label": {
"en": "Flood",
"fr": "Inondation"
"value": "winter",
"label": {
"en": "Winter storm, snow, ice",
"fr": "Tempête hivernale, neige, verglas"
"value": "cold",
"label": {
"en": "Cold, freeze, wind chill",
"fr": "Froid, gel, refroidissement éolien"
"value": "heat",
"label": {
"en": "Heat",
"fr": "Chaleur"
"value": "wind",
"label": {
"en": "Wind",
"fr": "Vent"
"value": "fire",
"label": {
"en": "Fire weather (red flag)",
"fr": "Risque d'incendie (red flag)"
"value": "fog",
"label": {
"en": "Fog",
"fr": "Brouillard"
"value": "air",
"label": {
"en": "Air quality, smoke, dust",
"fr": "Qualité de l'air, fumée, poussière"
"value": "marine",
"label": {
"en": "Marine, surf, rip currents",
"fr": "Mer, houle, courants"
"value": "other",
"label": {
"en": "Other",
"fr": "Autre"
"key": "level",
"label": {
"en": "Level",
"fr": "Niveau"
"description": {
"en": "Leave empty for every level{
"key": "alert_ended",
"label": {
"en": "NWS alert ended",
"es": "Fin de la alerta NWS"
"description": {
"en": "A watch, warning or advisory covering the house expired or was cancelled.",
"es": "Una vigilancia, alerta o aviso que cubría la casa expiró o fue cancelado."
"fields": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"es": "Casa"
"description": {
"es": "Nombre de la casa, exactamente como se muestra en Gladys. Dejar vacío para todas las casas."
"key": "event",
"type": "string",
"label": {
"en": "Event (e.g. Tornado Warning)",
"es": "Evento (ej. Advertencia de Tornado)"
"key": "category",
"type": "string",
"label": {
"en": "Kind (key)",
"es": "Tipo (clave)"
"key": "category_label",
"type": "string",
"label": {
"en": "Kind",
"es": "Tipo"
"key": "level",
"type": "string",
"label": {
"en": "Level (warning, watch, advisory, statement, other)",
"es": "Nivel (advertencia, vigilancia, aviso, declaración, otro)"
"key": "level_label",
"type": "string",
"label": {
"en": "Level label",
"es": "Etiqueta de nivel"
"key": "severity",
"type": "string",
"label": {
"en": "Severity (extreme, severe, moderate, minor, unknown)",
"es": "Gravedad (extrema, severa, moderada, menor, desconocida)"
"key": "urgency",
"type": "string",
"label": {
"en": "Urgency",
"es": "Urgencia"
"key": "certainty",
"type": "string",
"label": {
"en": "Certainty",
"es": "Certidumbre"
"key": "headline",
"type": "string",
"label": {
"en": "Headline",
"es": "Título"
"key": "area",
"type": "string",
"label": {
"en": "Area",
"es": "Área"
"key": "onset",
"type": "string",
"label": {
"en": "Start (local time)",
"es": "Inicio (hora local)"
"key": "ends",
"type": "string",
"label": {
"en": "End (local time)",
"es": "Fin (hora local)"
"key": "instruction",
"type": "string",
"label": {
"en": "Instructions",
"es": "Instrucciones"
"key": "description",
"type": "string",
"label": {
"en": "Description",
"es": "Descripción"
"key": "summary",
"type": "string",
"label": {
"en": "Summary",
"es": "Resumen"
"description": {
"en": "A sentence ready to put in a message.",
"es": "Una frase lista para poner en un mensaje."
"label": {
"description": {
"fields": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"es": "Casa"
"description": {
"key": "event",
"type": "string",
"label": {
"key": "category",
"type": "string",
"label": {
"en": "Kind (key)",
"type": "string",
"label": {
"en": "Kind",
"es": "Tipo"
"key": "level",
"type": "string",
"label": {
"type": "string",
"label": {
"key": "severity",
"type": "string",
"label": {
"key": "urgency",
"type": "string",
"label": {
"en": "Urgency",
"es": "Urgencia"
"key": "certainty",
"type": "string",
"label": {
"en": "Certainty",
"es": "Certidumbre"
"key": "headline",
"type": "string",
"label": {
"en": "Headline",
"es": "Título"
"key": "area",
"type": "string",
"label": {
"en": "Area",
"es": "Área"
"key": "onset",
"type": "string",
"label": {
"key": "ends",
"type": "string",
"label": {
"type": "string",
"label": {
"type": "string",
"label": {
"es": "Descripción"
"key": "summary",
"type": "string",
"label": {
"en": "Summary",
"es": "Resumen"
"description": {
}. Deje vacío para todas las casas."
"required": false
"key": "category",
"label": {
"description": {
"required": false,
"options": [
"value": "tornado",
"label": {
"en": "Tornado",
"fr": "Tornade"
"label": {
"label": {
"value": "flood",
"label": {
"en": "Flood",
"fr": "Inondation"
"value": "winter",
"label": {
"value": "cold",
"label": {
"value": "heat",
"label": {
"en": "Heat",
"fr": "Chaleur"
"value": "wind",
"label": {
"en": "Wind",
"fr": "Vent"
"value": "fire",
"label": {
"value": "fog",
"label": {
"en": "Fog",
"fr": "Brouillard"
"value": "air",
"label": {
"value": "marine",
"label": {
"value": "other",
"label": {
"en": "Other",
"fr": "Autre"
"key": "level",
"label": {
"en": "Level",
"fr": "Niveau"
"description": {
"en": "Leave empty for every level. A Watch means conditions are favorable; a Warning means the hazard is happening or imminent.",
"fr": "Laissez vide pour tous les niveaux. Une « Watch » signifie que les conditions sont réunies ; un « Warning » que le phénomène est en cours ou imminent."
"required": false,
"options": [
"value": "warning",
"label": {
"en": "Warning (take action)",
"fr": "Warning – alerte (agir)"
"value": "watch",
"label": {
"en": "Watch (be prepared)",
"fr": "Watch – veille (se préparer)"
"value": "advisory",
"label": {
"en": "Advisory",
"fr": "Advisory – avis"
"value": "statement",
"label": {
"en": "Statement",
"fr": "Statement – bulletin"
"value": "other",
"label": {
"en": "Other notice",
"fr": "Autre information"
"variables": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"fr": "Maison"
"key": "event",
"type": "string",
"label": {
"en": "Event",
"fr": "Événement"
"key": "category",
"type": "string",
"label": {
"en": "Kind (key)",
"fr": "Type (clé)"
"type": "string",
"label": {
"en": "Kind",
"fr": "Type"
"key": "level",
"type": "string",
"label": {
"en": "Level",
"fr": "Niveau"
"type": "string",
"label": {
"fr": "Libellé du niveau"
"key": "severity",
"type": "string",
"label": {
"en": "Severity",
"fr": "Sévérité"
"key": "area",
"type": "string",
"label": {
"en": "Area",
"fr": "Zone"
"key": "summary",
"type": "string",
"label": {
"en": "Summary",
"fr": "Résumé"
"description": {
"fr": "Une phrase prête à mettre dans un message."
"scene_actions": [
"key": "get_alerts",
"label": {
"en": "Get the NWS alerts",
"fr": "Obtenir les alertes NWS"
"description": {
"en": "The watches, warnings and advisories in force at the house, the most serious first.",
"fr": "Les veilles, alertes et avis en cours pour la maison, le plus grave en premier."
"timeout_seconds": 30,
"fields": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"fr": "Maison"
"description": {
"en": "Name of the house, as shown in Gladys. Leave empty for the first house with a location.",
"fr": "Nom de la maison, tel qu'affiché dans Gladys"dejar vacío para la primera casa localizada."
"required": false
"outputs": [
"key": "count",
"type": "number",
"label": {
"en": "Number of alerts",
"fr": "Nombre d'alertes"
"key": "has_alert",
"type": "boolean",
"label": {
"en": "Alert in force",
"fr": "Alerte en cours"
"key": "has_warning",
"type": "boolean",
"label": {
"en": "Warning in force",
"fr": "Warning en cours"
"key": "warnings",
"type": "number",
"label": {
"en": "Warnings",
"fr": "Warnings"
"key": "watches",
"type": "number",
"label": {
"en": "Watches",
"fr": "Watches"
"key": "advisories",
"type": "number",
"label": {
"en": "Advisories",
"fr": "Advisories"
"key": "events",
"type": "string",
"label": {
"en": "Events",
"fr": "Événements"
"key": "top_event",
"type": "string",
"label": {
"en": "Most serious: event",
"fr": "Plus grave : événement"
"key": "top_category",
"type": "string",
"label": {
"en": "Most serious: kind (key)",
"fr": "Plus grave : type (clé)"
"key": "top_category_label",
"type": "string",
"label": {
"en": "Most serious: kind",
"fr": "Plus grave : type"
"key": "top_level",
"type": "string",
"label": {
"en": "Most serious: level",
"fr": "Plus grave : niveau"
"key": "top_level_label",
"type": "string",
"label": {
"en": "Most serious: level label",
"fr": "Plus grave : libellé du niveau"
"key": "top_severity",
"type": "string",
"label": {
"en": "Most serious: severity",
"fr": "Plus grave : sévérité"
"key": "top_severity_label",
"type": "string",
"label": {
"en": "Most serious: severity label",
"fr": "Plus grave : libellé de la sévérité"
"key": "top_headline",
"type": "string",
"label": {
"en": "Most serious: headline",
"fr": "Plus grave : titre"
"key": "top_instruction",
"type": "string",
"label": {
"en": "Most serious: instructions",
"fr": "Plus grave : consignes"
"key": "top_ends",
"type": "string",
"label": {
"en": "Most serious: end (local time)",
"fr": "Plus grave : fin (heure locale)"
"key": "summary",
"type": "string",
"label": {
"en": "Summary",
"fr": "Résumé"
"description": {
"key": "get_forecast",
"label": {
"en": "Get the NWS forecast of a day",
"fr": "Obtenir la prévision NWS d'un jour"
"description": {
"en": "High, low, sky, chance of rain and wind of one day, with the forecaster's text.",
"fr": "Maximum, minimum, ciel, risque de pluie et vent d'une journée, avec le texte du prévisionniste."
"fields": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"fr": "Maison"
"description": {
"fr": "Nom de la maison, tel qu'affiché dans Gladys },
"required": false
"key": "day",
"type": "select",
"label": {
"en": "Day",
"fr": "Jour"
"required": false,
"default": "0",
"options": [
"value": "0",
"label": {
"en": "Today",
"fr": "Aujourd'hui"
"value": "1",
"label": {
"en": "Tomorrow",
"fr": "Demain"
"value": "2",
"label": {
"en": "In 2 days",
"fr": "Dans 2 jours"
"value": "3",
"label": {
"en": "In 3 days",
"fr": "Dans 3 jours"
"value": "4",
"label": {
"en": "In 4 days",
"fr": "Dans 4 jours"
"value": "5",
"label": {
"en": "In 5 days",
"fr": "Dans 5 jours"
"value": "6",
"label": {
"en": "In 6 days",
"fr": "Dans 6 jours"
"outputs": [
"key": "date",
"type": "string",
"label": {
"en": "Date (YYYY-MM-DD)",
"fr": "Date (AAAA-MM-JJ)"
"key": "name",
"type": "string",
"label": {
"en": "Period name",
"fr": "Nom de la période"
"key": "condition",
"type": "string",
"label": {
"en": "Sky (key)",
"fr": "Ciel (clé)"
"key": "condition_label",
"type": "string",
"label": {
"en": "Sky",
"fr": "Ciel"
"key": "short_forecast",
"type": "string",
"label": {
"en": "NWS short forecast",
"fr": "Prévision courte NWS"
"key": "temperature_max",
"type": "number",
"label": {
"en": "High",
"fr": "Maximum"
"key": "temperature_min",
"type": "number",
"label": {
"en": "Low",
"fr": "Minimum"
"key": "precipitation_probability",
"type": "number",
"label": {
"en": "Chance of rain (%)",
"fr": "Risque de pluie (%)"
"key": "wind_speed",
"type": "number",
"label": {
"en": "Wind (km/h or mph)",
"fr": "Vent (km/h ou mph)"
"key": "wind_direction",
"type": "string",
"label": {
"en": "Wind direction",
"fr": "Direction du vent"
"key": "detailed_forecast",
"type": "string",
"label": {
"en": "Forecast text, day (English)",
"fr": "Texte de la prévision, jour (anglais)"
"key": "detailed_forecast_night",
"type": "string",
"label": {
"en": "Forecast text, night (English)",
"fr": "Texte de la prévision, nuit (anglais)"
"key": "summary",
"type": "string",
"label": {
"en": "Summary",
"fr": "Résumé"
"description": {
"key": "get_current",
"label": {
"en": "Get the current NWS conditions",
"fr": "Obtenir les conditions actuelles NWS"
"description": {
"en": "The conditions measured at the nearest weather station, or forecast when it has not reported recently.",
"fr": "Les conditions mesurées à la station météo la plus proche, ou prévues quand elle n'a rien transmis récemment."
"fields": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"fr": "Maison"
"description": {
"fr": "Nombre de la casa, como se muestra en Gladys. Déjelo vacío para la primera casa con una ubicación.". Deje en blanco para la primera casa localizada."
"required": false
"outputs": [
"key": "temperature",
"type": "number",
"label": {
"en": "Temperature",
"es": "Temperatura"
"key": "apparent_temperature",
"type": "number",
"label": {
"en": "Feels like",
"es": "Sensación térmica"
"key": "humidity",
"type": "number",
"label": {
"en": "Humidity (%)",
"es": "Humedad (%)"
"key": "dew_point",
"type": "number",
"label": {
"en": "Dew point",
"es": "Punto de rocío"
"key": "pressure",
"type": "number",
"label": {
"en": "Pressure (hPa)",
"es": "Presión (hPa)"
"type": "number",
"label": {
"es": "Viento (km/h o mph)"
"key": "wind_gust",
"type": "number",
"label": {
"en": "Gusts (km/h or mph)",
"es": "Ráfagas (km/h o mph)"
"type": "string",
"label": {
"es": "Dirección del viento"
"key": "visibility",
"type": "number",
"label": {
"en": "Visibility (km or mi)",
"es": "Visibilidad (km o mi)"
"key": "condition",
"type": "string",
"label": {
"en": "Sky (key)",
"es": "Cielo (clave)"
"type": "string",
"label": {
"en": "Sky",
"es": "Cielo"
"key": "observed",
"type": "boolean",
"label": {
"en": "Measured by a station",
"es": "Medido por una estación"
"key": "station",
"type": "string",
"label": {
"en": "Station",
"es": "Estación"
"key": "observed_at",
"type": "string",
"label": {
"en": "Observed at (local time)",
"es": "Observado a (hora local)"
"key": "summary",
"type": "string",
"label": {
"en": "Summary",
"es": "Resumen"
"description": {
"widgets": [
"key": "alerts",
"label": {
"en": "NWS alerts",
"es": "Alertas NWS"
"description": {
"en": "Watches, warnings and advisories in force, with their full text.",
"es": "Vigilancias, alertas y avisos en vigor, con su texto completo."
"icon": "alert-triangle",
"settings": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"es": "Casa"
"description": {
"es": "Nombre de la casa, como se muestra en Gladys. Deje en blanco para la primera casa con una ubicación."
"required": false
"key": "forecast",
"label": {
"en": "NWS text forecast",
"es": "Pronóstico detallado NWS"
"description": {
"en": "The forecaster's narrative, period by period, with the NWS icons.",
"es": "El texto del pronosticador, período por período, con los iconos NWS."
"icon": "file-text",
"settings": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"es": "Casa"
"description": {
"required": false
"key": "show_icons",
"type": "boolean",
"label": {
"en": "Show the icons",
"es": "Mostrar los iconos"
"default": true
"key": "hourly",
"label": {
"en": "NWS next hours",
"es": "NWS hora por hora"
"description": {
"en": "Temperature, chance of rain or wind of the next hours, as a curve.",
"es": "Temperatura, probabilidad de lluvia o viento de las próximas horas, en curva."
"icon": "trending-up",
"settings": [
"key": "house",
"type": "string",
"label": {
"en": "House",
"es": "Casa"
"description": {
"required": false
"key": "metric",
"type": "select",
"label": {
"en": "Show",
"es": "Mostrar"
"default": "temperature",
"options": [
"value": "temperature",
"label": {
"en": "Temperature and feels like",
"es": "Temperatura y sensación térmica"
"value": "precipitation",
"label": {
"en": "Chance of rain",
"es": "Probabilidad de lluvia"
"value": "wind",
"label": {
"en": "Wind and gusts",
"es": "Viento y ráfagas"
"key": "hours",
"type": "select",
"label": {
"en": "Period",
"es": "Período"
"default": "24",
"options": [
"value": "12",
"label": {
"en": "12 hours",
"es": "12 horas"
"value": "24",
"label": {
"en": "24 hours",
"es": "24 horas"
"value": "48",
"label": {
"en": "48 hours",
"es": "48 horas"
Nueva integración: Servicio Meteorológico Nacional (pronósticos y alertas oficiales de los Estados Unidos)
¡Hola a todos!
Les presento una nueva integración externa para Gladys: Servicio Meteorológico Nacional (NWS), el servicio meteorológico oficial de los Estados Unidos. Proporciona a Gladys los pronósticos y, sobre todo, las alertas oficiales (tornados, huracanes, tormentas severas, inundaciones, tormentas de nieve, olas de calor…).
Solo es relevante para las casas ubicadas en los Estados Unidos y sus territorios (Alaska, Hawái, Puerto Rico, Guam…). Para una casa en otro lugar, Gladys pasa automáticamente al siguiente proveedor meteorológico.
Sin configuración
La API del NWS es gratuita y sin clave: instalan la integración y funciona de inmediato. Solo necesitan que la ubicación de la casa esté especificada en sus ajustes.
Lo que aporta
- Condiciones actuales medidas por la estación más cercana: temperatura, sensación térmica, humedad, punto de rocío, presión, viento, ráfagas, visibilidad.
- Pronósticos hora por hora durante 24 horas y pronósticos diarios durante 7 días.
- Amanecer y atardecer.
- Alertas oficiales con su texto completo y las instrucciones de seguridad.
Todo esto alimenta el widget meteorológico del tablero, el asistente y los disparadores «Alerta meteorológica» de Gladys.
Alertas en cuestión de segundos
Una advertencia de tornado suele durar de 30 a 45 minutos, mientras que Gladys verifica las alertas meteorológicas cada 30 minutos. La integración, por lo tanto, monitorea las alertas cada minuto (es ajustable) y notifica a Gladys tan pronto como una alerta cambia. Su escena se activa en cuestión de segundos.
También agrega dos disparadores dedicados, Alerta NWS emitida y Fin de una alerta NWS, con filtros:
- tipo de alerta: tornado, huracán, tormenta severa, inundación, tormenta invernal, frío, calor, viento, incendio, niebla, calidad del aire, mar…;
- nivel, según la escala estadounidense: Advertencia (actuar ahora), Alerta (prepararse), Aviso, Comunicado;
- gravedad y casa.
La integración sigue cada alerta a lo largo de su vida:
- una alerta extendida o actualizada no vuelve a activar la escena;
- una alerta que aumenta de nivel (por ejemplo, una Alerta de Huracán que se convierte en Advertencia de Huracán) la vuelve a activar;
- una interrupción breve de la API no termina la alerta por error.
Ejemplo: Alerta NWS emitida, tipo Tornado, nivel Advertencia → enviar un mensaje que contenga las variables Resumen y Instrucciones.
Acciones de escena
- Obtener las alertas NWS: el número de alertas, la más grave, sus instrucciones.
- Obtener el pronóstico NWS de un día: desde hoy hasta el día +6, con el texto del pronosticador.
- Obtener las condiciones actuales NWS.
Cada acción devuelve una frase Resumen lista para enviar en un mensaje.
Tres widgets
- Alertas NWS: contadores de advertencias/alertas/avisos, y el texto completo de cada alerta. El widget se actualiza tan pronto como una alerta cambia, lo cual es práctico en una tableta mural.
- Pronóstico NWS detallado: el texto del pronosticador período por período, con los iconos del NWS.
- NWS hora por hora: una curva durante 12, 24 o 48 horas, a elección para la temperatura y la sensación térmica, el riesgo de lluvia, o el viento y las ráfagas.
Ajustes opcionales
- Correo electrónico de contacto: el NWS solicita a cada aplicación que se identifique, y este correo electrónico le permite notificarle en lugar de bloquear su acceso.
- Duración de la caché (600 s por defecto).
- Intervalo de verificación de alertas (60 s por defecto, de 30 a 900 s).
Información útil
- El NWS redacta sus textos solo en inglés: nombres de alertas, boletines, textos de los pronosticadores. Todo lo demás sigue el idioma de Gladys (francés o inglés).
- El NWS no publica un índice UV.
- El campo Casa debe contener el nombre de la casa exactamente como en Gladys, incluyendo mayúsculas. Déjelo vacío para todas las casas.
- Se necesita Gladys 5.1.1 o más reciente.
Enlaces
- Código fuente y documentación: GitHub - William-De71/gladys-national-weather-service · GitHub
- Integración comunitaria, sin vínculo con el Servicio Meteorológico Nacional ni la NOAA.
Esta es la primera versión. Si viven en los Estados Unidos, o si simplemente quieren probarlo con una casa ubicada allí, sus comentarios me interesan mucho, especialmente durante un episodio real de alertas ![]()
