[External integration]: National Weather Service
For info, I’ve started the development of the external integration for the National Weather Service (National Weather Service)
A test image is available
Installing the test image from developer mode:
the docker image:
ghcr.io/william-de71/gladys-national-weather-service:dev
the manifest:
  "manifest_version": 1,
  "type": "weather",
  "name": "National Weather Service",
  "description": {
    "en": "Official US forecasts and alerts from the National Weather Service.",
    "fr": "Prévisions et alertes officielles du National Weather Service (États-Unis)."
  "version": "0.1.0",
  "docker_image": "ghcr.io/william-de71/gladys-national-weather-service:dev",
  "gladys_version": ">=5.1.1",
  "categories": [
    "environment"
  "cover_image": "https://raw.githubusercontent.com/William-De71/gladys-national-weather-service/main/cover.jpg",
  "transports": [
    "cloud"
  "location": true,
  "config_schema": [
      "key": "intro",
      "type": "section",
      "label": {
        "en": "Ready to use",
        "fr": "Prêt à l'emploi"
      "description": {
        "en": "Forecasts and alerts work with no configuration: the National Weather Service API is free and needs no key. It covers the United States and its territories only — a house elsewhere gets its weather from another provider.",
        "fr": "Les prévisions et les alertes fonctionnent sans configuration : l'API du National Weather Service est gratuite et sans clé. Elle ne couvre que les États-Unis et leurs territoires — une maison située ailleurs reçoit sa météo d'un autre fournisseur."
      "links": [
          "url": "https://www.weather.gov/documentation/services-web-api",
          "label": {
            "en": "NWS API documentation",
            "fr": "Documentation de l'API NWS"
      "key": "contact",
      "type": "string",
      "label": {
        "en": "Contact email (optional)",
        "fr": "Email de contact (optionnel)"
      "description": {
        "en": "Added to the identification the NWS requires from every application, so it can reach you before blocking traffic it finds abusive. Never shared with anyone else.",
        "fr": "Ajouté à l'identification que le NWS exige de chaque application, pour qu'il puisse vous prévenir avant de bloquer un trafic qu'il jugerait abusif. Jamais transmis à personne d'autre."
      "required": false,
      "placeholder": {
        "en": "me@example.com",
        "fr": "moi@exemple.fr"
      "key": "cache_duration",
      "type": "number",
      "label": {
        "en": "Cache duration (s)",
        "fr": "Durée du cache (s)"
      "description": {
        "en": "In seconds, between 0 and 3600. How long a forecast is reused before calling the NWS again. The NWS refreshes its forecasts about once an hour: the default of 600 (10 min) costs no freshness. Set to 0 to always call the API. Alerts are not affected: they are checked on their own schedule.",
        "fr": "En secondes, entre 0 et 3600. Durée pendant laquelle une prévision est réutilisée avant de rappeler le NWS. Le NWS met à jour ses prévisions environ une fois par heure : la valeur par défaut de 600 (10 min) ne fait rien perdre en fraîcheur. Mettre 0 pour toujours appeler l'API. Les alertes ne sont pas concernées : elles sont vérifiées selon leur propre rythme."
      "required": false,
      "default": 600,
      "min": 0,
      "max": 3600
      "key": "alert_check_interval",
      "type": "number",
      "label": {
        "en": "Alert check interval (s)",
        "fr": "Intervalle de vérification des alertes (s)"
      "description": {
        "en": "In seconds, between 30 and 900. How often the official alerts of your houses are checked, for the scene triggers and the alerts widget. A Tornado Warning lasts about 30 minutes: the default of 60 s fires your scenes within a minute of its issuance.",
        "fr": "En secondes, entre 30 et 900. Fréquence de vérification des alertes officielles de vos maisons, pour les déclencheurs de scène et le widget des alertes. Une alerte tornade dure environ 30 minutes : la valeur par défaut de 60 s déclenche vos scènes moins d'une minute après son émission."
      "required": false,
      "default": 60,
      "min": 30,
      "max": 900
  "scene_triggers": [
      "key": "alert_issued",
      "label": {
        "en": "NWS alert issued",
        "fr": "Alerte NWS émise"
      "description": {
        "en": "A new watch, warning or advisory covers the house. Its updates do not fire again. Checked every minute by default.",
        "fr": "Une nouvelle veille, alerte ou un avis du NWS couvre la maison. Ses mises à jour ne redéclenchent pas. Vérifié chaque minute par défaut."
      "fields": [
          "key": "house",
          "type": "string",
          "label": {
            "en": "House",
            "fr": "Maison"
          "description": {
            "en": "Name of the house, exactly as shown in Gladys. Leave empty for every house.",
            "fr": "Nom de la maison, exactement comme dans Gladys. Laissez vide pour toutes les maisons."
          "required": false
          "key": "category",
          "type": "multi_select",
          "label": {
            "en": "Kind of alert",
            "fr": "Type d'alerte"
          "description": {
            "en": "Leave empty for every kind.",
            "fr": "Laissez vide pour tous les types."
          "required": false,
          "options": [
              "value": "tornado",
              "label": {
                "en": "Tornado",
                "fr": "Tornade"
              "value": "hurricane",
              "label": {
                "en": "Hurricane / tropical storm",
                "fr": "Ouragan / tempête tropicale"
              "value": "thunderstorm",
              "label": {
                "en": "Severe thunderstorm",
                "fr": "Orage violent"
              "value": "flood",
              "label": {
                "en": "Flood",
                "fr": "Inondation"
              "value": "winter",
              "label": {
                "en": "Winter storm, snow, ice",
                "fr": "Tempête hivernale, neige, verglas"
              "value": "cold",
              "label": {
                "en": "Cold, freeze, wind chill",
                "fr": "Froid, gel, refroidissement éolien"
              "value": "heat",
              "label": {
                "en": "Heat",
                "fr": "Chaleur"
              "value": "wind",
              "label": {
                "en": "Wind",
                "fr": "Vent"
              "value": "fire",
              "label": {
                "en": "Fire weather (red flag)",
                "fr": "Risque d'incendie (red flag)"
              "value": "fog",
              "label": {
                "en": "Fog",
                "fr": "Brouillard"
              "value": "air",
              "label": {
                "en": "Air quality, smoke, dust",
                "fr": "Qualité de l'air, fumée, poussière"
              "value": "marine",
              "label": {
                "en": "Marine, surf, rip currents",
                "fr": "Mer, houle, courants"
              "value": "other",
              "label": {
                "en": "Other",
                "fr": "Autre"
          "key": "level",
          "label": {
            "en": "Level",
            "fr": "Niveau"
          "description": {
            "en": "Leave empty for every levelName of the house, exactly as shown in Gladys. Leave empty for every house.. Leave empty for all houses."
          "required": false
          "key": "category",
          "label": {
          "description": {
          "required": false,
          "options": [
              "value": "tornado",
              "label": {
                "en": "Tornado",
                "fr": "Tornade"
              "label": {
              "label": {
              "value": "flood",
              "label": {
                "en": "Flood",
                "fr": "Inondation"
              "value": "winter",
              "label": {
              "value": "cold",
              "label": {
              "value": "heat",
              "label": {
                "en": "Heat",
                "fr": "Chaleur"
              "value": "wind",
              "label": {
                "en": "Wind",
                "fr": "Vent"
              "value": "fire",
              "label": {
              "value": "fog",
              "label": {
                "en": "Fog",
                "fr": "Brouillard"
              "value": "air",
              "label": {
              "value": "marine",
              "label": {
              "value": "other",
              "label": {
                "en": "Other",
                "fr": "Autre"
          "key": "level",
          "label": {
            "en": "Level",
            "fr": "Niveau"
          "description": {
            "en": "Leave empty for every level. A Watch means conditions are favorable; a Warning means the hazard is happening or imminent.",
            "fr": "Laissez vide pour tous les niveaux. Une « Watch » signifie que les conditions sont réunies ; un « Warning » que le phénomène est en cours ou imminent."
          "required": false,
          "options": [
              "value": "warning",
              "label": {
                "en": "Warning (take action)",
                "fr": "Warning – alerte (agir)"
              "value": "watch",
              "label": {
                "en": "Watch (be prepared)",
                "fr": "Watch – veille (se préparer)"
              "value": "advisory",
              "label": {
                "en": "Advisory",
                "fr": "Advisory – avis"
              "value": "statement",
              "label": {
                "en": "Statement",
                "fr": "Statement – bulletin"
              "value": "other",
              "label": {
                "en": "Other notice",
                "fr": "Autre information"
      "variables": [
          "key": "house",
          "type": "string",
          "label": {
            "en": "House",
            "fr": "Maison"
          "key": "event",
          "type": "string",
          "label": {
            "en": "Event",
            "fr": "Événement"
          "key": "category",
          "type": "string",
          "label": {
            "en": "Kind (key)",
            "fr": "Type (clé)"
          "key": "category_label",
          "type": "string",
          "label": {
            "en": "Kind",
            "fr": "Type"
          "key": "level",
          "type": "string",
          "label": {
            "en": "Level",
            "fr": "Niveau"
          "key": "level_label",
          "type": "string",
          "label": {
            "en": "Level label",
            "fr": "Libellé du niveau"
          "key": "severity",
          "type": "string",
          "label": {
            "en": "Severity",
            "fr": "Sévérité"
          "key": "area",
          "type": "string",
          "label": {
            "en": "Area",
            "fr": "Zone"
          "key": "summary",
          "type": "string",
          "label": {
            "en": "Summary",
            "fr": "Résumé"
          "description": {
            "en": "A sentence ready to put in a message.",
            "fr": "Une phrase prête à mettre dans un message."
  "scene_actions": [
      "key": "get_alerts",
      "label": {
        "en": "Get the NWS alerts",
        "fr": "Obtenir les alertes NWS"
      "description": {
        "en": "The watches, warnings and advisories in force at the house, the most serious first.",
        "fr": "Les veilles, alertes et avis en cours pour la maison, le plus grave en premier."
      "timeout_seconds": 30,
      "fields": [
          "key": "house",
          "type": "string",
          "label": {
            "en": "House",
            "fr": "Maison"
          "description": {
            "en": "Name of the house, as shown in Gladys. Leave empty for the first house with a location.","en": "Name of the house, as shown in Gladys. Leave empty for the first house with a location.",
          "required": false
      "outputs": [
          "key": "count",
          "type": "number",
          "label": {
            "en": "Number of alerts",
            "fr": "Nombre d'alertes"
          "key": "has_alert",
          "type": "boolean",
          "label": {
            "en": "Alert in force",
            "fr": "Alerte en cours"
          "key": "has_warning",
          "type": "boolean",
          "label": {
            "en": "Warning in force",
            "fr": "Warning en cours"
          "key": "warnings",
          "type": "number",
          "label": {
            "en": "Warnings",
            "fr": "Warnings"
          "key": "watches",
          "type": "number",
          "label": {
            "en": "Watches",
            "fr": "Watches"
          "key": "advisories",
          "type": "number",
          "label": {
            "en": "Advisories",
            "fr": "Advisories"
          "key": "events",
          "type": "string",
          "label": {
            "en": "Events",
            "fr": "Événements"
          "key": "top_event",
          "type": "string",
          "label": {
            "en": "Most serious: event",
            "fr": "Plus grave : événement"
          "key": "top_category",
          "type": "string",
          "label": {
            "en": "Most serious: kind (key)",
            "fr": "Plus grave : type (clé)"
          "key": "top_category_label",
          "type": "string",
          "label": {
            "en": "Most serious: kind",
            "fr": "Plus grave : type"
          "key": "top_level",
          "type": "string",
          "label": {
            "en": "Most serious: level",
            "fr": "Plus grave : niveau"
          "key": "top_level_label",
          "type": "string",
          "label": {
            "en": "Most serious: level label",
            "fr": "Plus grave : libellé du niveau"
          "key": "top_severity",
          "type": "string",
          "label": {
            "en": "Most serious: severity",
            "fr": "Plus grave : sévérité"
          "key": "top_severity_label",
          "type": "string",
          "label": {
            "en": "Most serious: severity label",
            "fr": "Plus grave : libellé de la sévérité"
          "key": "top_headline",
          "type": "string",
          "label": {
            "en": "Most serious: headline",
            "fr": "Plus grave : titre"
          "key": "top_instruction",
          "type": "string",
          "label": {
            "en": "Most serious: instructions",
            "fr": "Plus grave : consignes"
          "key": "top_ends",
          "type": "string",
          "label": {
            "en": "Most serious: end (local time)",
            "fr": "Plus grave : fin (heure locale)"
          "key": "summary",
          "type": "string",
          "label": {
            "en": "Summary",
            "fr": "Résumé"
          "description": {
      "key": "get_forecast",
      "label": {
        "en": "Get the NWS forecast of a day",
        "fr": "Obtenir la prévision NWS d'un jour"
      "description": {
        "en": "High, low, sky, chance of rain and wind of one day, with the forecaster's text.",
        "fr": "Maximum, minimum, ciel, risque de pluie et vent d'une journée, avec le texte du prévisionniste."
      "fields": [
          "key": "house",
          "type": "string",
          "label": {
            "en": "House",
            "fr": "Maison"
          "description": {
            "fr": "Nom de la maison, tel qu'affiché dans Gladys[quote="alice, post:3, topic:42"]
How do I get started?
[/quote]
We're so glad you're here! Want to run your own Minecraft server? Just click the Get Started button below — it's easy.. Leave empty for the first house located."
          "required": false
      "outputs": [
          "key": "temperature",
          "type": "number",
          "label": {
            "en": "Temperature",
            "fr": "Température"
          "key": "apparent_temperature",
          "type": "number",
          "label": {
            "en": "Feels like",
            "fr": "Ressenti"
          "key": "humidity",
          "type": "number",
          "label": {
            "en": "Humidity (%)",
            "fr": "Humidité (%)"
          "key": "dew_point",
          "type": "number",
          "label": {
            "en": "Dew point",
            "fr": "Point de rosée"
          "key": "pressure",
          "type": "number",
          "label": {
            "en": "Pressure (hPa)",
            "fr": "Pression (hPa)"
          "key": "wind_speed",
          "type": "number",
          "label": {
            "en": "Wind (km/h or mph)",
            "fr": "Vent (km/h ou mph)"
          "key": "wind_gust",
          "type": "number",
          "label": {
            "en": "Gusts (km/h or mph)",
            "fr": "Rafales (km/h ou mph)"
          "key": "wind_direction",
          "type": "string",
          "label": {
            "en": "Wind direction",
            "fr": "Direction du vent"
          "key": "visibility",
          "type": "number",
          "label": {
            "en": "Visibility (km or mi)",
            "fr": "Visibilité (km ou mi)"
          "key": "condition",
          "type": "string",
          "label": {
            "en": "Sky (key)",
            "fr": "Ciel (clé)"
          "key": "condition_label",
          "type": "string",
          "label": {
            "en": "Sky",
            "fr": "Ciel"
          "key": "observed",
          "type": "boolean",
          "label": {
            "en": "Measured by a station",
            "fr": "Mesuré par une station"
          "key": "station",
          "type": "string",
          "label": {
            "en": "Station",
            "fr": "Station"
          "key": "observed_at",
          "type": "string",
          "label": {
            "en": "Observed at (local time)",
            "fr": "Relevé à (heure locale)"
          "key": "summary",
          "type": "string",
          "label": {
            "en": "Summary",
            "fr": "Résumé"
          "description": {
  "widgets": [
      "key": "alerts",
      "label": {
        "en": "NWS alerts",
        "fr": "Alertes NWS"
      "description": {
        "en": "Watches, warnings and advisories in force, with their full text.",
        "fr": "Veilles, alertes et avis en cours, avec leur texte complet."
      "icon": "alert-triangle",
      "settings": [
          "key": "house",
          "type": "string",
          "label": {
            "en": "House",
            "fr": "Maison"
          "description": {
            "fr": "Nom de la maison, tel qu'affiché dans Gladys. Laissez vide pour la première maison localisée."
          "required": false
      "key": "forecast",
      "label": {
        "en": "NWS text forecast",
        "fr": "Prévision NWS détaillée"
      "description": {
        "en": "The forecaster's narrative, period by period, with the NWS icons.",
        "fr": "Le texte du prévisionniste, période par période, avec les icônes NWS."
      "icon": "file-text",
      "settings": [
          "key": "house",
          "type": "string",
          "label": {
            "en": "House",
            "fr": "Maison"
          "description": {
          "required": false
          "key": "show_icons",
          "type": "boolean",
          "label": {
            "en": "Show the icons",
            "fr": "Afficher les icônes"
          "default": true
      "key": "hourly",
      "label": {
        "en": "NWS next hours",
        "fr": "NWS heure par heure"
      "description": {
        "en": "Temperature, chance of rain or wind of the next hours, as a curve.",
        "fr": "Température, risque de pluie ou vent des prochaines heures, en courbe."
      "icon": "trending-up",
      "settings": [
          "key": "house",
          "type": "string",
          "label": {
            "en": "House",
            "fr": "Maison"
          "description": {
          "required": false
          "key": "metric",
          "type": "select",
          "label": {
            "en": "Show",
            "fr": "Afficher"
          "default": "temperature",
          "options": [
              "value": "temperature",
              "label": {
                "en": "Temperature and feels like",
                "fr": "Température et ressenti"
              "value": "precipitation",
              "label": {
                "en": "Chance of rain",
                "fr": "Risque de pluie"
              "value": "wind",
              "label": {
                "en": "Wind and gusts",
                "fr": "Vent et rafales"
          "key": "hours",
          "type": "select",
          "label": {
            "en": "Period",
            "fr": "Période"
          "default": "24",
          "options": [
              "value": "12",
              "label": {
                "en": "12 hours",
                "fr": "12 heures"
              "value": "24",
              "label": {
                "en": "24 hours",
                "fr": "24 heures"
              "value": "48",
              "label": {
                "en": "48 hours",
                "fr": "48 heures"
:united_states: New Integration: National Weather Service (Official US Weather and Alerts)
I present to you a new external integration for Gladys: National Weather Service (NWS), the official weather service of the United States. It provides Gladys with forecasts and especially official alerts (tornadoes, hurricanes, severe thunderstorms, floods, snowstorms, heatwaves…).
It only concerns houses located in the United States and its territories (Alaska, Hawaii, Puerto Rico, Guam…). For a house elsewhere, Gladys automatically switches to the next weather provider.
:white_check_mark: No Configuration
The NWS API is free and key-free: you install the integration and it works immediately. You just need to have the house position entered in its settings.
:sun_behind_small_cloud: What It Brings
  • Current conditions measured by the nearest station: temperature, feels like, humidity, dew point, pressure, wind, gusts, visibility.
  • Hourly forecasts for 24 hours and daily forecasts for 7 days.
  • Sunrise and sunset.
  • Official alerts with their full text and safety instructions.
All of this feeds the weather widget on the dashboard, the assistant, and Gladys’s « Weather Alert » triggers.
:high_voltage: Alerts in a Few Seconds
A Tornado Warning often lasts 30 to 45 minutes, while Gladys checks weather alerts every 30 minutes. The integration therefore monitors alerts every minute (adjustable) and notifies Gladys as soon as an alert changes. Your scene is triggered in a few seconds.
It also adds two dedicated triggers, NWS Alert Issued and End of an NWS Alert, with filters:
  • alert type: tornado, hurricane, severe thunderstorm, flood, winter storm, cold, heat, wind, fire, fog, air quality, sea…;
  • level, according to the American scale: Warning (act now), Watch (get ready), Advisory, Statement;
  • severity and house.
The integration follows each alert throughout its life:
  • an extended or updated alert does not retrigger the scene;
  • an alert that escalates in level (for example, a Hurricane Watch that becomes Hurricane Warning) retriggers it;
  • a brief API outage does not end the alert by mistake.
Example: NWS Alert Issued, type Tornado, level Warning → send a message containing the Summary and Instructions variables.
:clapper_board: Scene Actions
  • Get NWS Alerts: the number of alerts, the most severe one, its instructions.
  • Get NWS Forecast for a Day: from today to day +6, with the forecaster’s text.
  • Get Current NWS Conditions.
Each action returns a Summary sentence ready to be sent in a message.
:bar_chart: Three Widgets
  • NWS Alerts: counters warnings / watches / advisories, and the full text of each alert. The widget updates as soon as an alert changes, which is practical on a wall tablet.
  • Detailed NWS Forecast: the forecaster’s text period by period, with the NWS icons.
  • NWS Hour by Hour: a curve over 12, 24, or 48 hours, at your choice for temperature and feels like, rain risk, or wind and gusts.
:gear: Optional Settings
  • Contact Email: NWS asks each application to identify itself, and this email allows it to notify you rather than block your access.
  • Cache Duration (600 s by default).
  • Alert Check Interval (60 s by default, from 30 to 900 s).
:information_source: Good to Know
  • NWS writes its texts in English only: alert names, bulletins, forecaster texts. Everything else follows Gladys’s language (French or English).
  • NWS does not publish a UV index.
  • The House field must contain the name of the house exactly as in Gladys, including capital letters. Leave it empty for all houses.
  • You need Gladys 5.1.1 or newer.
:link: Links
This is the first version. If you live in the United States, or if you just want to try it with a house located there, your feedback interests me a lot, especially during a real alert episode :tornado:
