Shellypil integration
To replace a faulty thermostat on a backup fridge, I wanted to use temperature conditions to start or stop the fridge’s power supply. For this, I used a ShellyPl.
In the external Shelly integration, the device is discovered, but when you save it, no functionality exists. I created a temperature widget, the temperature function is present but displays 45.5°C, whereas in the Shelly app the value is 7.8°C.
Hi @Francis66 :slight_smile:
I tag @Terdious, the developer of the external integration Shelly!
