Adding a Konyks TEMPO device in the Tuya integration (Terdious/gladys-tuya)
I just added a Konyks brand thermometer/hygrometer to Gladys via the Tuya integration. (Terdious/gladys-tuya)
The device is correctly discovered under the name « Termo XXX », but it displays « No functionality ».
Could you add it in a future update? Here are the device’s technical details:
  • Device name: Termo parents
  • Product ID (Tuya): oc5ayveauaz2ev4e
  • Tuya category: wsdc (Standard temperature & humidity sensor)
According to the characteristics of this category at Tuya, the device normally reports these functions:
  • Temperature (va_temperature) → to be linked to the feature temperature-sensor
  • Humidity (va_humidity) → to be linked to the feature humidity-sensor
  • Battery state (battery_state) → to be linked to the feature battery-sensor
Tuya device diagnostic — « Termo XXX »
model=Konyks Termo product_id=oc5ayveauaz2ev4e
category=wsdcg detected type=unknown mapped features=0
Cloud status (5 codes):
battery_state = « middle » [UNMANAGED]
humidity_value = 62 [UNMANAGED]
temp_current = 216 [UNMANAGED]
va_humidity = 62 [UNMANAGED]
va_temperature = 216 [UNMANAGED]
Declared enum ranges:
battery_state: low, middle, high (status+model)
A big thank you for your help and for the great work on this integration!
Hi @thomas and welcome to Gladys :slight_smile:
I ping @Terdious!
(@Terdious if you don’t have time right now, remember to give access to your repo to another developer so we can evolve the integration!)
He does regular evo (pull requests) on his repo but as far as I know, he’s pretty busy.
Could someone please contact them privately to ask for access to this external integration, so we can take over the torch? :slightly_smiling_face:
Hi @thomas,
Thanks for the request and the diagnostic report — it contained exactly what was needed (right down to the temperature scale and battery state range).
It’s been added in version 1.18.0 of the integration: your Konyks Termo should now be recognized as a temperature and humidity sensor, with:
  • Temperature (21.6 °C and not 216),
  • Humidity
  • and a Low Battery alert (triggered when the device goes into low battery mode),
  • usable in your scenes.
To activate it: update the integration, then in Discovery, update the device (it was created as type “unknown”).
Please check:
  • that the displayed temperature matches the one on the device screen,
  • that the values refresh after a reading (these battery-powered sensors only report at intervals, often several minutes),
  • and that the battery alert is set to “off” as long as the battery is fine.
If something is wrong, run “Device Diagnostics” and paste the report here.
Thanks to you!
Hello @Terdious, @pierre-gilles, and @spenceur,
thank you so much for this efficiency and speed.
i did some tests, Gladys correctly retrieves the information from the sensors.
For the data, I was helped by Copilot, who indicated the correct information to provide.
Thanks again.
Thomas
