Here are the logs I collected:
docker logs c06c09037746
[2026-10-24T10:09:23.279Z] [INFO] Starting the Marstek integration...
[2026-10-24T10:09:23.510Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-10-24T10:09:57.044Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T10:10:08.687Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T10:15:55.148Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T10:23:38.904Z] [INFO] Starting the Marstek integration...
[2026-10-24T10:23:39.209Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-10-24T10:23:53.484Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T10:25:17.724Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T10:25:22.414Z] [INFO] Starting the Marstek integration...
[2026-10-24T10:25:22.660Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-10-24T10:25:31.465Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string docker logs c06c09037746
Finally, in the Logs tab of the integration, there is the same information as in the logs of the docker container.
This morning I noticed that some information was added to the logs.
[2026-10-24T21:20:48.241Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T21:34:50.188Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T21:34:53.848Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T21:35:05.502Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T21:38:06.137Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T21:43:59.463Z] [INFO] Starting the Marstek integration...
[2026-10-24T21:43:59.674Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-10-24T21:45:09.922Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T22:02:02.820Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T22:03:31.573Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T22:03:47.007Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T22:04:04.550Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T22:04:16.234Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T22:05:14.222Z] [INFO] Configuration updated: restarting the polling
[2026-10-24T22:06:54.656Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[8].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-24T22:10:59.744Z] [WARN] [marstek] Publishing the devices failed: devices[0].features[9].supported_options: "[0].label" must be a string, "[1].label" must be a string, "[2].label" must be a string, "[3].label" must be a string, "[4].label" must be a string
[2026-10-25T01:05:14.553Z] [INFO] [marstek] Marstek Venus E 3.0 (192.168.1.55) does not support ES.GetStatus
[2026-10-25T08:29:45.078Z] [INFO] [marstek] Marstek Venus E 3.0 (192.168.1.55) does not support EM.GetStatus
