External integration: ability to read Gladys calendars from the SDK (for a CalDAV server)
I would like to create an external integration that exposes a CalDAV server, to be able to read Gladys calendars from other tools (Thunderbird, phone, Nextcloud…).
What I’ve seen in the SDK (integration-sdk-js)
  • The "calendar" type only allows pushing calendars and events to Gladys.
  • An integration only sees its own calendars, not those from other sources (internal CalDAV, Google, manually created events).
  • There is no method to read existing events.
  • However, exposing a port via sub-containers already works, so the CalDAV server part is not an issue.
My proposal
  • Add a read method to the SDK, for example getCalendarEvents(userSelector, { from, to }).
  • Keep the same principle as the existing one: the user activates the integration to give consent and chooses which calendars are shared.
  • A declaration in the manifest (e.g. "calendar_read": true) displayed during installation, like for "location": true.
Use cases
  • View Gladys events on your phone or in your email client.
  • Share a « home » calendar (trash, alarms, presence) with family.
  • Export to ICS for other tools.
Questions
  • Does this need interest other people?
  • Would this be feasible on the core / SDK side?
  • Or do you see a better approach (native ICS export in the core, for example)?
I am ready to develop the integration if the read method is added.
Thanks!
I would tend to say that it should be the core that centralizes all calendars and allows, via a server or an API, to read all the data.
This makes it possible to cover the case of several modules with calendars, such as public holidays, an electricity provider’s schedule, personal schedule, etc.
