You’re the best ![]()
The content is correct, but I meant visually. You see that the number is not centered. Maybe this can be corrected so that it is vertically and horizontally centered in the circle ![]()
@stefanbauer thanks, I see what you mean. This centering does not depend on the integration: it only sends the value and the unit, it is the heart of Gladys that draws the arc and places the figure in the tile. I can propose an improvement if needed.
I had the same thought about the gauge. It would be a great visual improvement!
hello I have a roborock Qrevo S Pro Set and everything works fine but the image of the house map is not the one from the application (which is in color) and here are my logs
and my last lines of the journal[2026-10-20T16:59:29.613Z] [WARN] [roborock:client] RPC get_consumable <- 1rQJCBxohmTS3L0pmeiXbq via local FAILED after 2675 ms: Roborock local transport closed
[2026-10-20T16:59:29.613Z] [WARN] [roborock:client] Local request failed for 1rQJCBxohmTS3L0pmeiXbq, falling back to cloud: Roborock local transport closed
[2026-10-20T16:59:29.614Z] [WARN] [roborock:client] Local request failed for 1rQJCBxohmTS3L0pmeiXbq, falling back to cloud: Roborock local transport closed
[2026-10-20T16:59:29.809Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203 route=300 battery=100 clean_time=3578s clean_area=62m² map_status=3 dock_error=0
[2026-10-20T16:59:51.796Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203 route=300 battery=100 clean_time=3578s clean_area=62m² map_status=3 dock_error=0
[2026-10-20T17:00:21.921Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203 route=300 battery=100 clean_time=3578s clean_area=62m² map_status=3 dock_error=0
[2026-10-20T17:00:51.923Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203 route=300 battery=100 clean_time=3578s clean_area=62m² map_status=3 dock_error=0
[2026-10-20T17:01:21.881Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203 route=300 battery=100 clean_time=3578s clean_area=62m² map_status=3 dock_error=0
[2026-10-20T17:01:51.924Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203 route=300 battery=100 clean_time=3578s clean_area=62m² map_status=3 dock_error=0
[2026-10-20T17:02:21.902Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203 route=300 battery=100 clean_time=3578s clean_area=62m² map_status=3 dock_error=0
[2026-10-20T17:02:51.903Z] [INFO] poll 1rQJCBxohmTS3L0pmeiXbq: state=8 (charging) error=0 in_cleaning=0 in_returning=0 fan=104 water=203
I created an issue about this integration: Robot injoignable/en veille : tempête de poll permanente (pas de back-off cloud, pas d'état « injoignable ») · Issue #20 · callemand/gladys-roborock · GitHub
I have a lot of furniture
