I installed the hyundai/Kia connect integration for my kia ev3 but I can’t connect after configuration, it also doesn’t work with a refresh token apparently Kia hasn’t been issuing them since the end of October or maybe I’m missing something. Thanks for your insights
Hi @Philippe44, thanks for reporting, you didn’t miss anything: it was indeed a bug on my end.
Since October 22, the Kia/Hyundai Europe login page has been rejecting applications that present themselves as an old Android browser, and that was the case for the integration: any new login was redirected to the form. Logins already open before this date, like @Prof_Techno’s, continued to work, hence the difference.
1.1.4 fixes this. Update from Gladys, re-enter your password (not the token) in the configuration, save, then click on Test Connection. Let me know if your EV3 appears ![]()
Magnificent, you are a magician, the car has appeared. A small subsidiary question, is it possible to manage the battery charge, start it, stop it according to a condition, for example, production of photovoltaic panels. Forgive me for using your skills, but I am an old geek and the intellect is no longer as sharp.
Super, glad your EV3 is there! ![]()
Yes, it’s possible: the car has a Charge feature (on/off), controllable from a scene with the action Control a device. You just need to enter the PIN code of the account in the settings; that’s what authorizes the commands.
For example, with your solar production sensor:
- Scene 1: when production exceeds 2,000 W, and if the car is Plugged in → Charge on on;
- Scene 2: when it drops below 1,000 W → Charge on off.
Keep a good gap between the two thresholds (or a condition “for 10 minutes”): each command goes through the Kia cloud to the car, takes up to two minutes, and the cloud doesn’t like being called every five minutes when a cloud passes ![]()
