Mail and Packages ; Mail and Packages
The integration published an incomplete or invalid device: Gladys refused to register it.
Rejected fields:
Feature “Last update” — Minimum value: required field not provided by the integration
Feature “Last update” — Maximum value: required field not provided by the integration
Technical details:
HTTP 422 — UNPROCESSABLE_ENTITY — t_device_feature.min cannot be null; t_device_feature.max cannot be null
Copy this detail if you ask for help on the forum or report the issue to the integration developer
the others are perfectly discovered and integrated
and my logs :
[2026-11-15T19:32:19.162Z] [INFO] Starting Mail and Packages…
[2026-11-15T19:32:19.362Z] [INFO] [gladys-sdk] connected to Gladys (http://172.30.0.1:80)
[2026-11-15T19:33:57.258Z] [INFO] [app] Configuration updated
[2026-11-15T19:33:59.380Z] [INFO] [engine] Scan: 6 carrier email(s), 0 active package(s)
[2026-11-15T19:34:13.506Z] [INFO] [actions] Action test_connection
[2026-11-15T19:34:20.563Z] [INFO] [actions] Action scan_now
[2026-11-15T19:34:22.193Z] [INFO] [engine] Scan: 6 carrier email(s), 0 active package(s)
[2026-11-15T19:36:40.462Z] [INFO] [app] Configuration updated
[2026-11-15T19:36:45.125Z] [INFO] [engine] Scan: 6 carrier email(s), 0 active package(s)
[2026-11-15T19:36:45.401Z] [INFO] [actions] Action test_connection
[2026-11-15T19:40:21.773Z] [INFO] [app] Configuration updated
[2026-11-15T19:40:23.483Z] [INFO] [engine] Scan: 6 carrier email(s), 0 active package(s)
[2026-11-15T19:45:30.701Z] [INFO] [engine] Scan: 6 carrier email(s), 0 active package(s)
